sea foam #854589 12/23/07 07:37 PM
W
walktastic Offline OP
has anybody used seafoam on their v6? i was curious if it works well at all and how to use it
V6 pickup 4x4, 385,000 miles and still ticking
Re: sea foam [Re: walktastic] #854590 12/23/07 10:21 PM
Adam F Offline
Used it on all my vehicles, V6 and 4cy. Honestly, it diddnt do anything for me. Just blew a bunch of smoke.
Unhook the PCV line and SLOWLY suck it in while the engine is running at 2000 or so RPM's.
97 4R, stock, daily driver
Re: sea foam [Re: Adam F] #854591 12/24/07 03:53 AM
P
PETE_YK Offline
Dont mean to intrude, but what is seafoam???
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: sea foam [Re: PETE_YK] #854592 12/24/07 04:02 AM
kewlynx Offline
They are a line of products; this one in particular is for de-carboning
linky
They also have an antigel additive for diesels.
**ubi apis- ibi salus**
Re: sea foam [Re: kewlynx] #854593 12/24/07 04:13 AM
Adam F Offline
They also make a aerosol can of the decarb stuff. I use it in my 2 stroke boat motor for winterizing. Remove spark plug, spray some in each cylinder, turn motor over a few times by hand, spray a bunch more in each cylinder, and replace plugs. Lubes the cylinders up and prevents corrosion.
Next season I'm going to give it a good healthy dose of decarb using seafoam. Supposedly its pretty important to decarb 2 stroke marine engines since they get carbon build up very easily.
Re: sea foam [Re: Adam F] #854594 12/24/07 07:55 PM
W
yeah i bought a can of the stuff and the guy at the store said to unplug my charcoal filter from the bottom and run it through that vaccuum line. is this correct?
Re: sea foam [Re: walktastic] #854595 12/24/07 08:01 PM
4Crawler Offline
That is how I used it on my 22RE a few years back. I found that the line was smaller and easier to control the fluid flow rate. Also a nice long hose and it connects up at the throttle body, so gets the cleaner onto all the intake.
Re: sea foam [Re: walktastic] #854596 12/24/07 11:15 PM
Adam F Offline
Any vaccum line will work.
Re: sea foam [Re: walktastic] #854597 12/25/07 06:03 AM
P
PETE_YK Offline
So is this stuff truly magical or will it eat valve seals and fuel lines like 90% of the additives out there??
Re: sea foam [Re: PETE_YK] #854598 12/25/07 11:44 AM
O
ovrrdrive Offline
Didn't do anything for me really either. It works at least as well as STP gas treatment.
It's basically a modern day snake oil with a huge following.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6446 MB (Peak: 0.7639 MB) Data Comp: Off Server Time: 2026-10-24 08:17:45 UTC
