Cardigan rebuild and jeep rolling without front drive shaft???? #854826 12/25/07 02:01 AM
trailboy Offline OP
I have a 93 ZJ with the double cardigan u joint at the t case. Mine was making a wierd squeaking noise and looks like it could use a rebuild, has anyone taken this thing apart? Also I have the front drive shaft out for now and parked on a small incline, and the jeep after about 1 hour or so it had rolled back about 10 feet, anyone ever seen this? <img src="/forums/images/graemlins/confused.gif" alt="" /> Any help would be appreciated.
Thanks
Tim
Re: Cardigan rebuild and jeep rolling without front drive shaft???? [Re: trailboy] #854827 12/25/07 04:35 AM
BigJim Offline
First guess on the rolling would be the park brake isn't adjusted properly.
Re: Cardigan rebuild and jeep rolling without front drive shaft???? [Re: BigJim] #854828 12/25/07 08:22 PM
Brown81CJ5 Offline
You can adjust the park brake by either adjusting the ratchet assymbly in the cab, or at the splitter in the rear under the body.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Cardigan rebuild and jeep rolling without front drive shaft???? [Re: trailboy] #854829 12/25/07 10:32 PM
80CJ Offline
Hope you don't mind a little correction. It's cardan. Cardigan is a sweater.
Re: Cardigan rebuild and jeep rolling without front drive shaft???? [Re: 80CJ] #854830 12/27/07 02:10 AM
trailboy Offline OP
At the time of these replies I hadn't set the parking brake, If I apply the brake, it works. The u-joints in the double CARDAN (not the cardigan sweater <img src="/forums/images/graemlins/smile.gif" alt="" />) the ball in there is worn. Someone on another board gave me a link that shows about fixing it and it even list part numbers.
Thanks to everyone for your help.
Tim
Re: Cardigan rebuild and jeep rolling without front drive shaft???? [Re: trailboy] #854831 12/27/07 03:45 AM
the_other_guy Offline
The reason it rolled is probably because it has a center differential (if it is a full time 4wd transfer case) with the front drive line removes it allowed the rear to turn. Even tho it was in park, the differential was still allowed to move. The parking brake is the only way to keep it from rolling because it stops the wheel itself from turning.
Your road to glory will be rocky, but fulfilling.
- Panda Express fortune cookie
94 YJ. no lift...YET
Re: Cardigan rebuild and jeep rolling without front drive shaft???? [Re: trailboy] #854832 01/13/08 09:15 PM
N
NedR Offline
I am working on a front driveshaft rebuild at present. Do you have the link to the rebuild information you found? Took mine apart and it appears to be a simple replacement of the three u joints. Chilton manual said the the rearmost joint could not be owner repaired!?
I just fix it, the kid drives.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6161 MB (Peak: 0.6934 MB) Data Comp: Off Server Time: 2026-06-07 09:07:38 UTC
