electricl problem #855059 12/27/07 01:05 AM
Dieselshop Offline OP
hey all
this morning my 85 4x4 22re would not start, I have power at the left side fuse pannel but i am not getting any power in side to the driver fuse pannel, I have nothing, no lights,radio,blower nothing. were does the power come in from the engine compartment. and ideas would really help. later.
Re: electricl problem [Re: Dieselshop] #855060 12/27/07 03:09 AM
kewlynx Offline
Start with the fusible link at your battery. Those like to rot when these trucks get to that age.
**ubi apis- ibi salus**
Re: electricl problem [Re: kewlynx] #855061 12/27/07 07:18 AM
IceBlueT Offline
X2
i was having issues as to where my truck would randomly die, and nothing would work. it was because the link was pulling off of the connector on the battery. it litteraly supplies power to everything except the main cable to the starter.
formerly 277000_yota
Old enough to know better, but still to damn arrogant to care...
]www.cardomain.com/ride/2614269
'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P)
'98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
Re: electricl problem [Re: IceBlueT] #855062 12/27/07 11:50 AM
I have power to the engine fuses next to the batery, were is the fuseable link located? thanks for the help
Re: electricl problem [Re: Dieselshop] #855063 12/27/07 12:41 PM
DRTDEVL Offline
It's the big 80 amp "fuse" in the box by the battery.
You gotta unbolt the box and unscrew the fusible link from the bottom.
BTW: How's Florida? <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: electricl problem [Re: DRTDEVL] #855064 12/27/07 11:59 PM
I was messing around with truck and low and behold the starter body has battey voltage, think that is a good place to start and is so shorted out that it is backfeeding through the ignition wire and whono were else. got to go get a starter and will get back to you all later.
Re: electricl problem [Re: Dieselshop] #855065 12/28/07 01:57 AM
turns out there is power everway, anough to light a test light, I can power the test l;ight from the bumper smile but anyway I just had a loose ground on the frame causeing all that trouble. smile lessons leared
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6187 MB (Peak: 0.6921 MB) Data Comp: Off Server Time: 2026-05-29 14:33:29 UTC
