what am I doing wrong? #855232 12/27/07 06:02 PM
captainpants Offline OP
I used to use this forum all the time but for some reason I can't search anything, always get 'no match'. I read the advanced tips but still having problems. I really need to replace my rotors on the 94 Rodeo and need help.
Re: what am I doing wrong? [Re: captainpants] #855233 12/27/07 06:11 PM
RobG Offline
are you selecting an appropriate date range? I believe the search defaults to only posts within the last week. You'll want to expand this to the past couple of years to drum up lots of results.
-Rob
Re: what am I doing wrong? [Re: RobG] #855234 12/27/07 09:04 PM
Gizzy42 Offline
Also make sure you use the plus signs (ie. +brake +rotor +replace). I usually clear the 'older then' section and use the 'new then' section and set it for like 3 yrs or something.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: what am I doing wrong? [Re: Gizzy42] #855235 12/28/07 12:08 AM
mlclark Offline
Isuzu Moderator
I don't know which link you are reading, but here is another tutorial that might help: LINK
The other problem you are going to find is that there is probably not a thread about replacing your rotors because it is clearly outlined in any Haynes, Chiltons or Helm manual. I suggest you do not do such a job without one.
If you run into trouble, we are here to help, but for the basic remove and replace stuff, someone was already nice enough to write it down and publish it a book for us.
Michael
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5985 MB (Peak: 0.6542 MB) Data Comp: Off Server Time: 2026-07-11 10:54:58 UTC
