4.3 INSTALL
#855305
12/27/07 11:37 PM
I know that there has been stuff on installing 4.3 in a Gen 1, But i'm a retard and can't find it. I am looking for info about mounting it in, brackets and the oil pan clearance. I have the 4 door troop transport model. Also if there is anything I should watch out for (heater core lines, etc). I understand that this is a project, not a weekend job. I am planning on using a 700r4 (non computer).
Blacktero: 90 Montero Lwb V6 RS Model. 16" Toyota Alloy Rims, Dual Bouncy's; Gen II Front Rotors & Calipers; Rear LSD
Sraider: 87 Raider 2.6 base. Work yet to be done.
Re: 4.3 INSTALL
[Re: heathdogg]
#855306
12/27/07 11:59 PM
Neat, I wish I could switch to something , like a diesel or I didn't say this here, a Toyo 3.4 supercharged. But that anothe pipe dream.
I have never been able to get anything from the archive system here. I'm no geek , you must have to be a very special kind of geek , too.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
Re: 4.3 INSTALL
[Re: heathdogg]
#855307
12/28/07 12:09 AM
I know that there has been stuff on installing 4.3 in a Gen 1, But i'm a retard and can't find it. I am looking for info about mounting it in, brackets and the oil pan clearance. I have the 4 door troop transport model. Also if there is anything I should watch out for (heater core lines, etc). I understand that this is a project, not a weekend job. I am planning on using a 700r4 (non computer). Put quotes around 4.3 like this... "4.3" Then make sure you select both the Tech and Archive forums. Then make sure you change the date range to maybe 2+ years That should bring up lots of posts talking about it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 4.3 INSTALL
[Re: off-roader]
#855308
12/28/07 01:22 AM
Also search My username, LeeRaider, BigBlue, Don. We've all done 4.3 swaps, and I think a few more, but those are the ones I remember right now.
Re: 4.3 INSTALL
[Re: LandRaider]
#855309
12/28/07 01:24 AM
I am also thinking about doing this. Once it warms back up around here next this spring.
Re: 4.3 INSTALL
[Re: Chris_J]
#855310
12/28/07 01:29 AM
I am also thinking about doing this. Once it warms back up around here next this spring. Your scared of a ARB, what makes you think you can pull off a 4.3 swap <img src="/forums/images/graemlins/lol.gif" alt="" /> don't kill me <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: 4.3 INSTALL
[Re: LRJ4x4]
#855311
12/28/07 06:35 AM
Not scared its halfway apart in the garage right now. Its a little cold. Not Socal hippie land here sorry. And its about 30 degrees once the weather gets back to normal. Learning process. And have you looked at a breakdown of an RD05? Lots of little parts. And getting parts from the west coast takes a while around the holidays. Ordered them a weekand a half ago just got them so :*****: <img src="/forums/images/graemlins/cheers.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 4.3 INSTALL
[Re: Chris_J]
#855312
12/28/07 06:50 AM
Just so were clear I'm in NorCal treehugger-ville <img src="/forums/images/graemlins/smile.gif" alt="" />
I think Don has a great 4.3 post somewhere but the 4x4wire search is buggy
Re: 4.3 INSTALL
[Re: LRJ4x4]
#855313
12/28/07 03:20 PM
Gotcha <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 4.3 INSTALL
[Re: Chris_J]
#855314
12/30/07 10:03 PM
You can email me and I will help you. Superchief87@adelphia.net
