Help with Header Leak #855674 12/28/07 08:28 PM
SALMONHEAD Offline OP
So my 22r was equiped with a hedman header when I got it and the lower front bolt was missing/broken. It appeared that the block/header gasket area had been smeared with a red sealant. It is now leaking pretty bad. The exposed remaining studs all look pretty bad (rusty, bad threads) so I'm not sure how to proceed. I've got a feeling as soon as I start to pull the header more studs are going to break off. So how does the easy out/ rethread business go when the engine is still in the truck? I appreciate any ideas.
Thanks
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: Help with Header Leak [Re: SALMONHEAD] #855675 12/29/07 04:40 PM
Dieselshop Offline
On that side there is plenty of room to work if you break a bolt, and once you get it off the might be anought of the bolt expose to pull it out, just spray them all down really good and let me soak over night plus make sure you have a new gasket and new replacement bolts or studs. a good impact gun help.
Re: Help with Header Leak [Re: Dieselshop] #855676 12/30/07 06:26 AM
I have never had to drill into a block and my previous attempt with as "easy out" wasn't easy at all. It seemed like it was difficult to keep centered and I don't own a tap set. I was hoping to get some specific directions on how to get this done without screwing up my block.
I saw stud sets for sale at $40 which seemed kind of high. I also hoped someone could tell me what the best gasket would be.
Thanks
Re: Help with Header Leak [Re: SALMONHEAD] #855677 12/30/07 09:15 AM
F
flyinhawaiian Offline
This may help in removing the bolts....
http://www.apple.queensu.ca/CJ3B/Tech/BoltRemoval.html
Re: Help with Header Leak [Re: flyinhawaiian] #855678 12/30/07 07:13 PM
daveowen Offline
im interested to nkow the bestgasket to! The BRAND NEW one i put on there has already cracked and making alot of noise!
Re: Help with Header Leak [Re: daveowen] #855679 12/31/07 12:35 AM
1
1986xtracab Offline
OEM gaskets are far better in most cases. yes they are more money but are worth it.
1986 xtra-cab 22re
stock everything
1991 bed
Re: Help with Header Leak [Re: 1986xtracab] #855680 12/31/07 05:55 AM
Well, thanks for the input. I am starting to assemble my parts. I ordered the header & collector gaskets for the hedman and I'll call around to see if I can find a stud set locally. The "KROIL" penetrating oil looks good but I don't see it around here. Is there a second best that is more common (NAPA, Autozone)?
Thanks & Almost Happy New Year!
Re: Help with Header Leak [Re: SALMONHEAD] #855681 12/31/07 05:59 AM
4Crawler Offline
AutoZone usually carries PB Blaster that works pretty good. You can order Kroil from http://kanolabs.com/. they'll usually send you a free or reduced price trial can.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6205 MB (Peak: 0.6984 MB) Data Comp: Off Server Time: 2026-07-09 21:40:08 UTC
