Oil Filter Base Bracket Replacement #855684 12/28/07 09:47 PM
BajaxjH4l Offline OP
Hello, I am new on this forum and needless to say I need help. I have a 1993 jeep cherokee HO 4l in which I have a oil leak. The engine oil leak is at the Oil Filter base bracket; the one side that attaches to the engine block. It seems that there is some sort of screw holding the base bracket to the block on the engine but I can not get it out, worse, I think onthe effort of trying to remove it (since I can not see it) I have broke (damage) this screw. Has anybody done the replacement of this part before? what screw type is it (torx?)
thanks for the help.
93' XJ H4L 3.5" Lift on 31's M/S. Tow's well behind the Motorhome (E450 V10).
Re: Oil Filter Base Bracket Replacement [Re: BajaxjH4l] #855685 12/28/07 11:04 PM
A
Airdale73013 Offline
I am preparing to replace my o-rings on the oil filter adapter. The part number for the Mopar kit is 1-04720363 and it cost $6.01 at my dealer. You will need a 14mm hex (allen) wrench which will fit inside the screw at the center of the adapter.
2009 Sorento LX, 4x4, V6, Auto, Red
Re: Oil Filter Base Bracket Replacement [Re: Airdale73013] #855686 12/29/07 05:29 PM
Thanks Airdale<
I will try that. Since I was able to put a mirror in there to the screw type, I think is not going to be easy since I beleive the screw head is damage. I have to fix it some how since it leaks a lot.
I will come back with my findings.
Re: Oil Filter Base Bracket Replacement [Re: BajaxjH4l] #855687 01/08/08 05:03 AM
Just in case someone follows this trail in the future.
-14 mm Allen Key from Napa $6.95.
-"short" leg of the Allen key too long to fit $$#@#. <img src="/forums/images/graemlins/angry.gif" alt="" />
-Cutting the Allen key to fit at the machineshop at the office ,$Free. <img src="/forums/images/graemlins/lol.gif" alt="" />
-Getting the "screw" on the base lose, $ a lot of effort. <img src="/forums/images/graemlins/scared.gif" alt="" />
-Finding out that no "o" ring gascket was installed before, $@#!$. <img src="/forums/images/graemlins/zombie.gif" alt="" />
- Fixing the oil leak, Priceless!!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
All was done while is was raining in San Diego on Sunday.
Again, Thanks for the help.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6015 MB (Peak: 0.6568 MB) Data Comp: Off Server Time: 2026-06-07 00:27:36 UTC
