tire envy #855930 12/30/07 12:17 AM
jkrubicon Offline OP
this truck belongs to a wrecker company in Orange TX. It was built to recover offroaders from the local pipelines and High Lines.[Linked Image]
I would rather be tried by 12 than carried by 6
Re: tire envy [Re: jkrubicon] #855931 12/31/07 12:31 AM
PartyTruck Offline
What sort of terrain are they dealing with ??
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: tire envy [Re: PartyTruck] #855932 12/31/07 01:36 AM
reepersteve Offline
Emagine the gear ratio. What do you think it is? I'll say somewhere in 8's <img src="/forums/images/graemlins/mrt.gif" alt="" />
01' TJ Wangler, 6" Ruff Country X Series, 35" x 12.5" Mickey Thompsons On 15 x 10" rims w/ simi Bead Lock, Matching Warn Bumpers, 9500xi Warn Wench, Tom Woods Drive Shaft And SYE, And A K+N Cool Air Intake. Still Improving
Re: tire envy [Re: jkrubicon] #855933 01/01/08 02:23 AM
The trcuk was built to recover vehicles from pipelines and other remote locations.It has a factory 5.9L cummings engine. and sets on 5 1/2 ton military axles, with a 5 1/2 ton t-case. alot of the trucks in the area are running 38's or better. the terrain in this part of texas is mostley swampland. It is in the South East corner of Texas Bordering Laouisianna
Re: tire envy [Re: jkrubicon] #855934 01/01/08 03:52 AM
BobRowe Offline
Those tires are a hellova lot taller than 38's!
Re: tire envy [Re: BobRowe] #855935 01/01/08 04:30 AM
BigJim Offline
I betcha they are closer to 58's than 38's..
Re: tire envy [Re: BigJim] #855936 01/01/08 02:10 PM
reepersteve Offline
Hey Jim maybe you should start hanging tires on your living room wall and take the deer heads down. I bet those tires could be prize winners. You can call the amount of knobs, points. These tires could be a 36 point roller at 58"s. You can hang one over your mantle. <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: tire envy [Re: reepersteve] #855937 01/02/08 07:09 AM
jstritec Offline
I'm concerned about the tire rubbing the driver's head off at full stuff.
80 CJ-7.
It runs
Re: tire envy [Re: jstritec] #855938 01/03/08 01:50 AM
F
Fred Blackstone Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> Good one, Josh! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: tire envy [Re: jkrubicon] #855939 01/03/08 05:36 PM
I was saying that most of the trucks in that area are running 38's or bigger. those are actually 63" according to the owner of the truck.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6356 MB (Peak: 0.7584 MB) Data Comp: Off Server Time: 2026-07-14 11:07:04 UTC
