Need help identifying my chevy front axle #856134 12/30/07 11:42 PM
huskyohilux Offline OP
I baught a pair of chevy 4x4 axles from a blazer or silverado. But I'm not sure if the front is a chevy 10 bolts, dana or what. The form of the diff cover doesn't look like any of the pictures I've found on a 10 bolt axle. Actually it looks a lot like the chevy 12 bolts. I need help with identifying it so that I can buy the right ARB air locker kit.
I'm building a toyota pick up truck with souped up chevy 305 from a camaro 1982, 12 bolt rear axle, trail gear 4.70:1 reduction kit, toyota stock 5 spd manual gear box, 38" bogger TSL.
I also need some input regarding the strenght of the axles...will they hold up <img src="/forums/images/graemlins/confused.gif" alt="" /> to the 3000 lbs of toyota truck going offroad?
Re: Need help identifying my chevy front axle [Re: huskyohilux] #856135 01/02/08 03:36 AM
We'll need photos or some information on the donor vehicle. Many crawlers here near the Rubicon use Chevy axles on V8 Toyotas with little problem. Photos.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Need help identifying my chevy front axle [Re: rxinhed] #856136 01/02/08 06:10 PM
Brown81CJ5 Offline
My guess is that the front is a Dana 44.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Need help identifying my chevy front axle [Re: rxinhed] #856137 01/03/08 10:09 AM
I have pictures of the axle but I don't have them online. Is there a way to post pics on this forum?
My guess is either a dana 44 or GM 10 bolt but the diff cover doesn't look like 100% alike either one...is there any other way of telling?
Re: Need help identifying my chevy front axle [Re: huskyohilux] #856138 01/03/08 05:18 PM
Brown81CJ5 Offline
Do you know the year of the vehicle they came out of?
Gun it and run it!
Re: Need help identifying my chevy front axle [Re: Brown81CJ5] #856139 01/03/08 10:00 PM
IIRC, the D-44 / Corporate 10-bolt break year was 80/81. The D-44 break rotors are solid in the area between the lugs and the rotor face, the 10-bolts are perforated. The D-44 will have a '44' cast in the housing flange in the lower right section of the differential housing, too, viewed when facing the differential cover.
Re: Need help identifying my chevy front axle [Re: Brown81CJ5] #856140 01/03/08 10:39 PM
I think late 70th but I?m not sure...they were just laying around some guys yard...
Gonna check the rotors and the casting on the diff housing
Re: Need help identifying my chevy front axle [Re: huskyohilux] #856141 01/04/08 02:58 AM
Brown81CJ5 Offline
Hopefully it's out of a '76, if it is it would be a 44. <img src="/forums/images/graemlins/smile.gif" alt="" />
As Rxinhed stated,the 44 will have 44 cast into the housing. Now that I remember the 10 bolt will have a 3 digit code on the housing.
Gun it and run it!
Re: Need help identifying my chevy front axle [Re: Brown81CJ5] #856142 02/25/08 03:22 PM
Still haven't made a positive identification...
The casting on the back of the differential sais:
GM3
458856 N
C228?
Cover is bolted w/ 10 bolts
Re: Need help identifying my chevy front axle [Re: huskyohilux] #856143 02/25/08 06:45 PM
Brown81CJ5 Offline
This might help...it has some basic pics and stats of axles.
axle id chart
Notice the bolt patterns on the 10 bolt and 44. That should help you figure it out. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Gun it and run it!
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6375 MB (Peak: 0.7603 MB) Data Comp: Off Server Time: 2026-06-07 07:18:57 UTC
