ISUZU WIZARD (4JX1) STARTING PROBLEM
#856214
12/31/07 05:19 AM
I have a 1999 Isuzu Wazard that has a starting problem. On mornings the engine will crank but will not start. If you leave it for awhile and them try to start the engine again, it may start mormally. Once the you get it started in the morning the engine will start normally during the rest of the day. I have been advised by my technician to replace the crank and cam sensors as no code is showing up on the scanner. Please advise you my possible causes are, this vehicle has been doing this for the last six months, presently it is in the workshop as it refused to start two weeks ago.
2 (0%, 0 Votes)
1 (0%, 0 Votes)
Re: ISUZU WIZARD (4JX1) STARTING PROBLEM
[Re: Tyrone]
#856215
12/31/07 03:00 PM
Start with the KIKI and check output power on glowup. If OK isolate each glow plug and check resistance. Also since it's unlikely that you'll have an ammeter capable of 20 amps, you can just touch the + probe of your voltmeter to the tip of one of the glow plugs...........the - probe to ground...........and you should see approx. 12V during the 30 seconds immediately following the turning of the key to the #2 position
86 Isuzu Trooper TD 5 speed 82 Isuzu Diesel I-Mark 86 300 SDL MB 126 85 300SD MB 126 82 300 D MB 123
[Re: TX76513]
#856216
01/04/08 04:36 PM
I have since replaed the four glow plugs, but the problem continues
[Re: Tyrone]
#856217
08/09/10 06:58 PM
try changing your engine oil put 5w30
[Re: Tyrone]
#856218
09/28/10 04:19 AM
i would suggest going over to the isuzu trooper owners club uk (itocuk) they have more experience with these engines there and can problem help you a great deal more than over here. good luck!
86 Turbo Diesel 4dr Trooper 4JB1TC 89 turbo diesel Trooper-RED
PHP: 7.4.33 Page Time: 0.011s Queries: 20 (0.009s) Memory: 0.6166 MB (Peak: 0.7436 MB) Data Comp: Off Server Time: 2026-07-16 03:40:41 UTCValid HTML 5 and Valid CSS
