2002 trooper oil use[ 1 quart in 3000 miles] #856258 12/31/07 06:13 AM
srf Offline OP
is there anything i can do to stop the oil use. the tail pipe stays black while in town but goes light grey when i go on a long road trip. is there anything that i can replace in the motor to help this. sorry if there is a post already on line but i couldn't find it. any info would be helpful. ps. what is the best oil that i should use in this truck. using penzoil 10w-30 now. thanks srf.
Re: 2002 trooper oil use[ 1 quart in 3000 miles] [Re: srf] #856259 12/31/07 06:25 AM
holger Offline
There were plenty of threads about the oil consumption here.
1Qt per 3000 miles sounds normal for this engine. Just check the oil level often.
I personally use 0W-40 Mobil1 to control the consumption. Others report that Rotella heavy-duty (or synthetic) is the best oil in terms of consumption. But in your situation there is nothing to worry about if you keep the level between the marks.
Oleg
Deceased Rodeo'02 4WD.
Re: 2002 trooper oil use[ 1 quart in 3000 miles] [Re: holger] #856260 12/31/07 01:39 PM
srf Offline OP
thank you for the reply. have a good new year in 2008. thanks srf.
Re: 2002 trooper oil use[ 1 quart in 3000 miles] [Re: srf] #856261 12/31/07 10:53 PM
MoogVO Offline
I agree. I have seen brand new cars that use that much and the dealer said it is normal. I wouldn't lose any sleep over it.
Tom Moog
1994 Trooper LS
Re: 2002 trooper oil use[ 1 quart in 3000 miles] [Re: srf] #856262 01/02/08 07:43 PM
trentch Offline
try using a sea foam engine cleaner available at most napa parts stores. disconnect your brake boost line from master cylinder and poor half a can down that tube. pouring the fluid is the key though don't stick the vacuum hose into the cleaner or you may get a vapour lock. the other half of the can poor into your crank case. after about 100km change the oil. do this a couple of times and it should solve your issue. mine worked on a 99rodeo! hope it helps
Re: 2002 trooper oil use[ 1 quart in 3000 miles] [Re: trentch] #856263 01/03/08 10:42 AM
joey011582 Offline
so what causes it, rings sticking or design flaw?
Re: 2002 trooper oil use[ 1 quart in 3000 miles] [Re: joey011582] #856264 01/08/08 03:47 AM
srf Offline OP
thanks for the replies, very helpful. srf.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6183 MB (Peak: 0.6925 MB) Data Comp: Off Server Time: 2026-11-02 23:31:24 UTC
