water pump question #856366 12/31/07 10:09 PM
troopinn Offline OP
does the water pump run off of the timing belt or the fan pully/serpintine belt? I recently changed the serpintine belt and now the fan pulley rocks and makes noise and I get a rocking noise coming out of the engine....ind of confused as as to what is going on, are they related or are they two seperate things going on?
Re: water pump question [Re: troopinn] #856367 12/31/07 10:32 PM
boritz Offline
G'day,
I'm assuming that you are talking about the V6?
If so, then yes, the water pump is driven by the timing-belt. It is mounted into the front of the engine block, behind the timing covers.
In regards to your noises - try running the motor without the serpentine belt - that will eliminate noises coming from it's drive train.
Noises from the timing-belt train could be: water-pump, idler pulley, tensioner pulley or faulty hydraulic tensioner.
Do a search on 'tensioner' over the last few months
Aussie 1997 3.2V6 SOHC 6VD1 Holden Jackaroo SE (Isuzu Trooper/Bighorn/Monterey) 5-speed manual, rear LSD, front Lokka (manual free-wheel hubs).
Re: water pump question [Re: troopinn] #856368 12/31/07 11:05 PM
troopinn Offline OP
soory forgot to say....it is a '99 trooper 3.5L. The mechanic I showed it to swears the water pump bearing is where the noise is from and that is also why the fan pulley has splay as well....I guess my question is does the fan pulley have anything to do with the water pump?
Re: water pump question [Re: troopinn] #856369 01/01/08 12:41 AM
Gizzy42 Offline
The fan isnt driven off the water pump. Its attached to the 'fan bracket' and thats most likely what is causing the noise. Isuzu lists 2 different ones depending on the month it was made.
BRACKET; FAN 8-97148-675-1 08-1997 to 07-1999
BRACKET; FAN 8-97231-718-0 08-1999 and LATER
If you go to myisuzuparts.com and do a search for one of those part numbers you can see an exploded diagram of what it looks like.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: water pump question [Re: Gizzy42] #856370 01/03/08 07:10 AM
troopinn Offline OP
after discussing it with you guys and my dad, who has changed a timing belt on a couple of troopers...(every person in my family has a troopper!), I asked the mechanic I showed my car to why he thinks it is the water pump...and I also explained to him that the fan pulley and the water pump do not have anything to do with eachother...he got really bent out of shape...so I did not let him anywhere near my truck!!
Took the belt off and it turns out that the idler pulley is really worn out...
Thanks for your help...the tech guys on this site are really awsome...
just goes to show you that you should question every thng that just doesn't add up... <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Re: water pump question [Re: troopinn] #856371 01/09/08 08:33 PM
troopinn Offline OP
well got that fixed and now the fan pulley is making the same "rocking" noise. It does not sound the same as when the idler pulley and tensioner pulley were making noise though....not really sure if it is coming from the engine or what...when I rev it it disappears....
what online source do you guys use for parts....I think Ineed a fan bracket, is the pulley part of the bracket assembly or is it different?
Re: water pump question [Re: troopinn] #856372 01/09/08 11:47 PM
trentch Offline
just playing devils advocate but have you tested your fan clutch? Try spinning it 6 full rotations or more in one direction is a bad thing. i recently had this happen to my rodeo. on startup it was an intermittent kind of grinding noise.
99 rodeo lse
Re: water pump question [Re: troopinn] #856373 01/10/08 04:52 PM
DieselBob Offline
Not exactly online but I have used St. Charles Isuzu a couple of times and have had great service and very good pricing <img src="/forums/images/graemlins/cheers.gif" alt="" /> compared to local dealers. Contact Merlin @ 800-727-8066.
Bob
"You can't expect to wield supreme executive power just 'cause some watery tart threw a sword at you."
02 Trooper S, TOD, Aisin Hubs, FJORD Blue, ARB 3444070 Winch Bar. Dueler A/T REVO LT265/75R16
Re: water pump question [Re: DieselBob] #856374 01/10/08 10:11 PM
lttlbddy Offline
And free shipping!!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6261 MB (Peak: 0.7299 MB) Data Comp: Off Server Time: 2026-06-09 18:18:52 UTC
