Y does my 86 warm up differnnt than my 89? #856415 01/01/08 12:30 AM
Boyota Offline OP
I have an 86 runner that starts fine but warms up at the same rpm all the way through and takes a long time.
My 89 pick up w half the miles
warms up at about 2200 then drops to about 1700 after a bit, then slows its way down to about 1000.
Takes about 1/4 the time of the runner
So what controls this
Is my 86 capable of this?
I'm givin up my toy and goin VWesty. Got my Westy and another Toy:)
Re: Y does my 86 warm up differnnt than my 89? [Re: Boyota] #856416 01/01/08 03:18 AM
kewlynx Offline
Are they both 22RE's? When's the last time you've given the system a good descaling and flush?
**ubi apis- ibi salus**
Re: Y does my 86 warm up differnnt than my 89? [Re: Boyota] #856417 01/01/08 08:53 PM
4Crawler Offline
The early and late model 22REs have a different cold start/auxiliary air valve. On the early model, it is separate from the throttle body and on the later models, it is part of the TB. The late model air valve is supposed to work better and can be retrofitted to the earlier engine with an intake swap.
Re: Y does my 86 warm up differnnt than my 89? [Re: kewlynx] #856418 01/03/08 01:33 AM
Boyota Offline OP
Both are 223re's
What is descaling? and how to?
Re: Y does my 86 warm up differnnt than my 89? [Re: 4Crawler] #856419 01/03/08 01:34 AM
Boyota Offline OP
That I'll have to go check out.
Thanks
Always a help!!
Re: Y does my 86 warm up differnnt than my 89? [Re: Boyota] #856420 01/03/08 02:34 AM
4Crawler Offline
Both are 223re's
Removing cooling system deposits from the various temperature sensing parts. Basically, remove the part, clean and replace. Something like a wire brush, or vinegar or a bathrrom cleaner like CLR works well.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6121 MB (Peak: 0.6813 MB) Data Comp: Off Server Time: 2026-05-30 01:06:37 UTC
