Rough Idle #856427 01/01/08 01:34 AM
Redboar Offline OP
I have a 1985 22RE. Put in a rebuilt short block and new EB head and cam about 1300 miles ago. Engine starts and runs great when it is cold; starts idling rough as it warms up and gets much worse when it is hot.
I have checked for vacuum leaks, misrouted hoses, egr, timing and adjusted valves. I have found two things that might be contributing to it. One, when I put the timing light on #3 & #4 cylinder I see a miss sometimes. The other thing is when I did a compression check, I got the following.
#1= 135
#2= 120
#3= 125
#4= 118
Squirting oil into the cylinders only raised it about 7 psi.
I know these figures are way low, but how long does it take for the rings to seat? Any other ideas or suggestions as to what I can check or is causing the bad idle?
Thanks.
85 SR5 4X4 XTRA, 22RE
W56, Marlin Crawler 4.7
4" lift, 4.88
Re: Rough Idle [Re: Redboar] #856428 01/01/08 01:35 AM
DRTDEVL Offline
You need to get that sucker out and run the pi$$ out of it, ASAP!
Gotta seat those rings someday...
Re: Rough Idle [Re: Redboar] #856429 01/01/08 05:22 AM
yota4runna Offline
Sounds like a vacuum leak. A good way to find a leak in the intake system is to spray carb cleaner over your intake hoses and manifold gaskets with the engine idling. The EGR valve is a prime suspect, too. A speck of carbon inside can keep it from seating, and cause a hard to find vacuum leak. Best way to eliminate the EGR as a possibility is to unbolt it from the head, slip a blank gasket behind it, and bolt it back up.
As for the compression readings, do you have a National Institute of Standards and Technology certificate for that gauge? I get two different readings from my two gauges and learned a long time ago to not worry about what the absolute numbers are, but to worry when I see one number very different from the others. And even then, just removing the plugs to do the check can dislodge a piece of carbon which can hold a valve open slightly temporarily. So, don't jump to too many conclusions based on a compression check.
Re: Rough Idle [Re: yota4runna] #856430 01/02/08 12:47 AM
Redboar Offline OP
I have been driving the pi$$ out of it and will do some more when I get this idle problem cleared up. I will borrow another pressure gauge just to check out how close mine is.
I have sprayed all around the hoses and gaskets and nothing shows up. I will try blocking off the EGR and see if that helps.
Can you tell what the missing that is shown by the means?
Thanks for the replies.
4" lift, 4.88
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6028 MB (Peak: 0.6593 MB) Data Comp: Off Server Time: 2026-11-15 21:18:51 UTC
