I need a new key made... #856539 01/01/08 11:06 PM
jwheelin1 Offline OP
Which lock cylinder has the key code stamped on it? Right or left door? I need to have some new keys cut for my 1988 4Runner. The locks/ign. work fine, but my keys are very worn down and won't stay in the ignition. Getting tired of looking for my keys on the floor when I'm wheelin'. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: I need a new key made... [Re: jwheelin1] #856540 01/02/08 02:18 AM
A
aptech Offline
just do like me and take them out and put them in your pocket. kindof like the fact i take the keys out and have the truck running. maybe i just got use to it. a tdealer should be able to cut a key. pay for one and home depote the rest
Re: I need a new key made... [Re: jwheelin1] #856541 01/02/08 02:22 AM
kewlynx Offline
Seems to me they both should have them. It seems to me the dealer can take your VIN and look it up for you as well, presuming the truck is later than '82.
**ubi apis- ibi salus**
Re: I need a new key made... [Re: jwheelin1] #856542 01/02/08 02:38 AM
yota4runna Offline
Key code should be on right door lock cylinder.
Re: I need a new key made... [Re: yota4runna] #856543 01/02/08 03:33 AM
Thanks. I didn't want to take apart the wrong side for no reason. Not a big fan of the dealer for anything, but may give em a shot at this first. I will probably end up at the locksmith though. As for just taking the key out of the ignition...tried that but if I gotta shut down quickly for some reason I'm screwed.
Re: I need a new key made... [Re: jwheelin1] #856544 01/02/08 04:34 AM
Runner-Man Offline
Take the lock to the dealer, they'll make you a new key for a few bucks. Then go to Lowes / hardware store, etc. and have another key made. Lock up your original Toyota key or carry it in your wallet as a spare in case you lock yourself out. In 5-6 years when your 'everyday use' key doesn't look like a key anymore, pull our your original key and have a copy made. Repeat.
Re: I need a new key made... [Re: jwheelin1] #856545 01/02/08 07:46 AM
daveowen Offline
run a kill switch off the battery / ignition.
Re: I need a new key made... [Re: daveowen] #856546 01/03/08 03:41 AM
Well...the dealership(at least mine here) said that their database only went back ten years. My 4runner is coming up on its 20th birthday in august. Pulling the door lock is not difficult at all, just more work than I want to do for a key. None the less, I took the door apart and will have a few new keys by tomorrow. Thanks for everyones input. Jeff
Re: I need a new key made... [Re: jwheelin1] #856547 01/03/08 03:41 AM
F
freeskithetrees Offline
Take VIN and registration or title to dealer. They look up the vin to get the code. They cut a key, give you the code and you walk out with a new key.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6268 MB (Peak: 0.7136 MB) Data Comp: Off Server Time: 2026-10-24 23:15:04 UTC
