Major tune up for 22-RE engine needed??? #856859 01/02/08 07:03 PM
Corona Offline OP
What do I need to do to keep my engine running another 100K miles??? Its a '90 4WD PU with 167000 miles. Valves were adjusted at about 70000, plugs and wires replaced 2 or 3 times, but no other work has been done. I assume it is time to replace the timing chain. But what else?
Re: Major tune up for 22-RE engine needed??? [Re: Corona] #856860 01/03/08 01:21 AM
Jeffstoyo Offline
What about the water pump? With that many miles on the rig.
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: Major tune up for 22-RE engine needed??? [Re: Corona] #856861 01/03/08 03:26 AM
kewlynx Offline
Do a leakdown and compression test for the heck of it, so you've got some baseline numbers in the future. Yep, time for TC maintenance.
I would suggest the injectors getting cleaned, but if you're gas mileage is still okay, and you're not having a hard start first thing, they're still fine (leaking injectors depressurize the fuel rail).
Clean your MAF and T'body. The articles for the 3.0 for this stuff is similar; up in the Yota section above.
**ubi apis- ibi salus**
Re: Major tune up for 22-RE engine needed??? [Re: Corona] #856862 01/03/08 02:52 PM
Kaptain Offline
You're are probably due for a timing chain replacement - I would pull the valve cover to make sure your guides are there. If they are and you're not hearing it 'slap' around then you are OK for the time being.
In addition to that you will want to replace the water pump, and refill with fresh Toyota Coolant.
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: Major tune up for 22-RE engine needed??? [Re: Kaptain] #856863 01/07/08 05:10 PM
Corona Offline OP
Thank you for your you're suggestions everyone.
Re: Major tune up for 22-RE engine needed??? [Re: Corona] #856864 01/09/08 01:31 AM
A
aptech Offline
good start
lots of good tips a info.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6078 MB (Peak: 0.6769 MB) Data Comp: Off Server Time: 2026-06-07 07:05:03 UTC
