intake manifold torque specs 99 rodeo lse 3.2v6
#856868
01/02/08 08:02 PM
the haynes manual states 17lbs torque on the lower intake, does anyone have any updates on this tourqe spec as well as the plenum? i'm about to start the gasket replacement process. Thank's!
99 rodeo lse
Re: intake manifold torque specs 99 rodeo lse 3.2v6
[Re: trentch]
#856869
01/03/08 01:16 AM
G'day, Yes, Isuzu manual says 18 lb-ft for all intake manifold bolts (near enough to your 17). 62Mb PDF workshop manual download for the V6 http://www.spottedhaggis.com/isuzu/090.pdfIt's for the Trooper but the engine/trans sections are applicable.
Aussie 1997 3.2V6 SOHC 6VD1 Holden Jackaroo SE (Isuzu Trooper/Bighorn/Monterey) 5-speed manual, rear LSD, front Lokka (manual free-wheel hubs).
[Re: boritz]
#856870
01/03/08 02:24 AM
13 ft lbs. Isuzu revised it a while ago. There is a TSB about it but I dont remember which one at the moment. Make sure you use an inch lb wrench as a ft lb torque wrench wont be accurate enough at that low of a setting.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed 32x11.50-15 BFG T/A KO on US Wheel 94 series 3" Lift - Rancho 9000x Rear No-Slip Locker Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
[Re: Gizzy42]
#856871
01/03/08 02:43 AM
Isuzu Moderator
Just for clarification, what is it. lb-ft or lb-in?
13lb-ft is 156lb-in. I think most lb-in wrenches can do that, but low range lb-ft wrenches are out there too.
Just don't put 13lb-ft on a 13lb-in bolt. Actually, you won't get there. It will break long before you get that tight. <img src="/forums/images/graemlins/smile.gif" alt="" />
Good Luck, Michael
[Re: mlclark]
#856872
01/03/08 03:57 AM
Its ft lbs. I always recommend converting to inch lbs and using an inch lb wrench at that low of a setting for accuracy and most ppl dont have low range ft lb wrenches.
--Dave
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6075 MB (Peak: 0.6721 MB) Data Comp: Off Server Time: 2026-06-07 08:36:10 UTCValid HTML 5 and Valid CSS
