Engine swap single versus dual #856899 01/02/08 09:40 PM
Coastal Offline OP
I have a 93 montero 3.o single overhead cam looking for an engine.. I found one but it is dual. Will it work and are there any probems i will encounter. I am sure this has been covered before, but having problems with the search.. Thanks for any info..
Re: Engine swap single versus dual [Re: Coastal] #856900 01/02/08 10:48 PM
How are your existing heads? I "think" (or I arrived at this conclusion by using the process I use instead of thinking) that you can swap your heads and FI and spark onto the dohc block, with only maybe having to drill the new oil filter adapter mounting location and plugging the old one. IIRC, the motor mount may seal off the old location, but I'm a little paranoid about that. I'd tap and plug...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5869 MB (Peak: 0.6348 MB) Data Comp: Off Server Time: 2026-06-07 11:33:45 UTC
