Temp gauge on 87' 22RE
#856987
01/03/08 01:21 AM
When my son starts his truck, he says the temp gauge instantly goes up about halfway and stays there for a few minutes...then drops to cold, then bounces back up to halfway...I think the gauge itself must be bad...is there anyway to test it?...the truck does not over-heat
thanks for any help
Re: Temp gauge on 87' 22RE
[Re: wheelin34m]
#856988
01/03/08 03:26 AM
That behavior is typical of these "dampened" gauges. I believe there is a test procedure - maybe an ohm spec in the factory service manual.
I may have a spare if you want one, depending on which cluster you have, but my suggestion is to live with it as a toyota-ism...
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
[Re: dcg9381]
#856989
01/03/08 03:54 AM
Yep. My temp gauges do this, too. Not a problem.
[Re: yota4runna]
#856990
01/03/08 12:58 PM
J Roll Me Over
All of our '87's do it...
Get an aftermarket gauge and plumb it into the block drain (lower driver's side of the engine block).
[Re: wheelin34m]
#856991
01/04/08 07:39 PM
I've found that If I punch/hit the cluster when the gauge pegs it'll go back to normal! Probably won't continue to do that for long, though.
I recall seeing a thread on this where somebody FINALLY fixed the problem- whoever it was put claw washers on the ground screws on the back of the clusters and torqued the hell out of them, digging the washer into the metal. Worth a shot...
[Re: VanillaTHUNDA]
#856992
01/04/08 08:23 PM
J Roll Me Over
I recall seeing a thread on this where somebody FINALLY fixed the problem- whoever it was put claw washers on the ground screws on the back of the clusters and torqued the hell out of them, digging the washer into the metal. Worth a shot... Yeah... I followed that closely. It worked for about a month, then quit again.
[Re: wheelin34m]
#856993
01/15/08 08:03 AM
My 87 temp gauge stabbed me in the back. The damn thing got stuck at normal temp when one of the aux. coolant hoses busted. I don't know how long I was driving with an over temped engine, but when I finally noticed smoke I flicked the dash and the gauge swung up to "melt down" level. A long tow and one head gasket later I was back on road. But I'll never trust that gauge again.
---------------------- '87 4Runner
[Re: Chunky]
#856994
01/16/08 03:26 AM
mines never done that before <img src="/forums/images/graemlins/confused.gif" alt="" /> maybe im just lucky.
87' ext cab toy
[Re: Chunky]
#856995
01/16/08 09:14 PM
Yeah, I've had that happen to me at one point- fortunately I caught it before any real damage was done. I pulled off and opened the hood to see my exhaust manifold cherry red- scary stuff!
