header #857038 01/03/08 02:58 AM
A
ak92toyota Offline OP
thinking about buying a pacesetter header for my 22re just wondering if any one has one if they do add horsepower/save on fuel? thanks
Re: header [Re: ak92toyota] #857039 01/06/08 07:21 AM
hodgepodge79 Offline
I'd say skip the header. I have a Thorley tri-y header, and it's ok, but not worth the $ nor the hastle of install (5 of my exhaust manifold studs ended up stripping out of the head).
Check this out. http://www.4x4wire.com/forums/showf...p;amp;sb=5&o=all&fpart=1
Stay with the factory manifold and upgrade the tailpipe, cat, and muffler.
Then use the rest of the money you saved put it towards a new cam, differential locker, or sliders in a few more months.
Re: header [Re: hodgepodge79] #857040 01/06/08 07:55 PM
O
outdoorfan Offline
Re: header [Re: hodgepodge79] #857041 01/07/08 09:01 PM
drainsbe Offline
x2
Dave
86 4Runner, 22R-EB
Re: header [Re: outdoorfan] #857042 01/17/08 05:31 PM
Jeepeater Offline
Oh, what the heck. I don't want to feel left out.
x3
Re: header [Re: ak92toyota] #857043 01/17/08 08:23 PM
SALMONHEAD Offline
I'm trying to fix my leaky header gasket & stripped bolt hole now and I agree - don't bother unless you have a cam, oversize valves and are looking for upper RPM power.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: header [Re: SALMONHEAD] #857044 01/17/08 09:16 PM
Spacetrucking Offline
Salmon, think my truck has leak there too.
Do you get a ticking sound at idle, or sort of a diesel
sound when lauching from low rpm's?
( the rod bearings are fine, valves a bit out,
ticking sound under 1500 rpm )
Hugh
'86 SR-5 Extra-cab 4 x 4, 2" BL, 33 x 12.5 x 15R M/T on 15 x 8 rockcrawlers ( 3 3/4" BS ), 22RE 5 sp , 4.88's Detroit True-Trac front, V6 open rear, 24 mm Sway-Away + Rancho 5000's, removed sway bar, no-rust south US bed, Ramsey 8000 winch
Re: header [Re: ak92toyota] #857045 01/18/08 04:50 AM
A
i went ahead and bought it anyway cause my exhast manifold was cracked i got to say it was a easy install and it added quite a bit more power
Re: header [Re: Spacetrucking] #857046 01/18/08 08:21 PM
SALMONHEAD Offline
Mine is a LOUD ticking sound and I can see where the gasket is blown out on lower front header flange. The last time I heard a loud ticking sound it was the number one plug that had unscrewed it self.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6204 MB (Peak: 0.7069 MB) Data Comp: Off Server Time: 2026-06-13 10:49:20 UTC
