the ultimate aftermarket engine warmer? #857096 01/03/08 10:43 AM
hacker Offline OP
Its starting to hit single digits around here and a warmer wouldn't be a bad idea for now. Found this one..
http://www.jcwhitney.com/autoparts/...-p_CATENTRY_ID:1000002061965000002000836
It inserts in the cooling lines and circulates warmed coolant throughout the motor. Is this one worth it? 50 bucks ain't bad
~~_/) ~~
www.maps.org
Re: the ultimate aftermarket engine warmer? [Re: hacker] #857097 01/03/08 04:26 PM
playinmud Offline
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: the ultimate aftermarket engine warmer? [Re: playinmud] #857098 01/03/08 05:32 PM
BigJim Offline
(Big Jim down on his knees) Thank you Lord for keeping me ignorant of such matters! I know nothing of these and please don't allow me to learn.
Re: the ultimate aftermarket engine warmer? [Re: BigJim] #857099 01/03/08 06:57 PM
Brown81CJ5 Offline
I'm not a fan of cold weather either BJ!
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: the ultimate aftermarket engine warmer? [Re: hacker] #857100 01/03/08 09:38 PM
bhartwell59 Offline
sure wouldn't hurt to get heat into the cabin faster but i thought the real issue was the oil being too cold to crank the engine over, no?
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: the ultimate aftermarket engine warmer? [Re: bhartwell59] #857101 01/03/08 10:19 PM
F
Fred Blackstone Offline
Texas isn't exactly a cold region! It's time for the mountain, northern tier, and Canadian folks to advise.
Re: the ultimate aftermarket engine warmer? [Re: bhartwell59] #857102 01/04/08 02:09 AM
playinmud Offline
wow now that you mention it ive never seen a oil pan blanket (except on semis), maybe because we have oil that still flows well in cold temperatures
Re: the ultimate aftermarket engine warmer? [Re: playinmud] #857103 01/04/08 03:15 AM
fishtaker Offline
When I was in Wisconsin, I had a freeze plug pulled and a heating element put in to warm the coolant in the block. It kept the block warm which kept the oil warm.
The tranny was a different story. Sure learned to park in the gear I was going to use first.
03 TJ 5 Speed I-6 30X9.50 BFG KO's
Re: the ultimate aftermarket engine warmer? [Re: playinmud] #857104 01/04/08 03:35 AM
beakie Offline
-24*C here lately... that block heater is the ticket. they come stock in most vehicles up this way. -24 isn't all that cold when it hits -30 without the wind chill. BigJim we have an extra bed up here if ya wanna enjoy the powder for a bit.
97xj 4.0L cold air, Banks, Flowmaster Exhuast, 99 intake, 4.5", 33's
Re: the ultimate aftermarket engine warmer? [Re: beakie] #857105 01/04/08 03:49 AM
BigJim Offline
I might take you up on the bed when the skeeters are romanc'n but if the skeeters ain't happy neither am I.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6378 MB (Peak: 0.7615 MB) Data Comp: Off Server Time: 2026-07-14 12:37:10 UTC
