'00 4Runner Transmission Woes... #857742 01/05/08 04:13 AM
Johnboy Offline OP
Posting for my father-in-law...
He has a 2000 4Runner with an auto and full time 4x4. It has 77,000 miles. The transmission light came on and he took it to the stealership. The fluid was changed a shift soleniod or two replaced. The transmission light came back on and the stealership threw up their arms and asked for $5K for a new transmission.
The trans works and shifts fine except for two major issues.
1. Overdrive does not work
2. When your foot goes off the gas the engine falls back to 1100 rpm-no matter what speed.
I'm hoping ya'll can give me a little direction where the dealership has chosen to be incompetent.
BTW - I do realize that this will most likely still be a costly repair.
TIA,
John
85 4Runner, 4" lift, bumpers, sliders, locker
Re: '00 4Runner Transmission Woes... [Re: Johnboy] #857743 01/05/08 05:00 AM
kewlynx Offline
Go to our Taco section here. There is a sticky with factory service manuals in it; your year is one of them. You can get the codes read at any box store for free and run the troubleshooting tree accordingly.
Good luck!
**ubi apis- ibi salus**
Re: '00 4Runner Transmission Woes... [Re: kewlynx] #857744 01/05/08 05:08 AM
G
Greg_Canada Offline
Post up on yotatech, theres a few knowledgeable peeps on the 3rd gen runners around there...
89 4Runner
Re: '00 4Runner Transmission Woes... [Re: kewlynx] #857745 01/05/08 05:56 AM
kewlynx Offline
Found this in the TSB's for that rig over at www.bedlib.org
05/24/2002 AUTOMATIC TRANSMISSION FLUID REQUIREMENTS
06/10/2003 ECM RESET MEMORY FUNCTION AFTER A/T REPLACEMENT OR REPAIRS
12/17/2003 ECM RESET MEMORY FUNCTION AFTER TRANSMISSION REPAIR/REPLACEMENT - REVISED
06/10/2004 ECM RESET MEMORY FUNCTION - REVISED
12/20/2004 ECM RESET MEMORY FUNCTION AFTER A/T REPLACEMENT OR REPAIRS - REVISED
12/15/2004 A340 TRANSMISSION SOLENOID IDENTIFICATION
Betcha 5 bucks they didn't reset the ECU like they needed to.
Re: '00 4Runner Transmission Woes... [Re: kewlynx] #857746 01/05/08 03:41 PM
Adam F Offline
I wonder if you could reset the ECU by unhooking the battery and let it sit for a half hour or so? Or do you have to use their code reader?
97 4R, stock, daily driver
Re: '00 4Runner Transmission Woes... [Re: Adam F] #857747 01/07/08 02:26 AM
kewlynx Offline
Method #2 is to disconnect the battery, but I'm under the impression it still needs a driveability test to get it to get it to behave properly afterward.
Re: '00 4Runner Transmission Woes... [Re: kewlynx] #857748 01/07/08 02:48 AM
Jake97T Offline
I was under the impression that the engine goes back to idle speed while coasting normally...since the torque converter isnt locked up...
Re: '00 4Runner Transmission Woes... [Re: Jake97T] #857749 01/07/08 05:40 AM
Johnboy Offline OP
Even from 3000 rpm to 1100 rpm at highway speeds? That seems out of the ordinary to me but its not my car and I'm used to driving a stick.
He's giving the battery disconnect a try tomorrow. Hopefully that works.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6240 MB (Peak: 0.7219 MB) Data Comp: Off Server Time: 2026-07-16 08:52:06 UTC
