Re-Built Engine Surging #857843 01/05/08 07:44 PM
AndyR Offline OP
I Rebuilt the 4ZE1 engine in my 88 Trooper about 6000 miles ago, and i has had a weird "surging" problem since about 3000. Let me explain: when the engine is under stress at low RPM such as 2000 RPM going up a steep hill, the engine will surge like one or two of the cylinders are not firing. This also happens uder engine braking at low RPM. The lights also surge. I took it to a mechanic, and he said it might be the voltage regulator (btw, is this built into the alternator?) because the voltage varies about a volt. I will check the regulator probably today and post the results. Hopefully some of you have had ecperience with this? Oh, and when I blew a head gasket and pulled the head, two of the cyliners were black with what looked like fowling/carbon buildup.
1988 Trooper II in the works.
Re: Re-Built Engine Surging [Re: AndyR] #857844 01/05/08 07:58 PM
strawmyers Offline
Isuzu Moderator
Yes the regulator is internal to the alt. There should be some level of carbon build-up inside the engine. If the other 2 cylinders were shiney and new looking, its probably because coolant was leaking in and essentially steam cleaning them.
Sean Strawmyer
Re: Re-Built Engine Surging [Re: strawmyers] #857845 01/05/08 09:00 PM
AndyR Offline OP
Ya, I guess thats true about the coolant. I didnt think of that.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5955 MB (Peak: 0.6495 MB) Data Comp: Off Server Time: 2026-06-07 07:24:27 UTC
