Crank Bolt #857846 01/05/08 07:50 PM
drainsbe Offline OP
Is there a good way to remove a stripped crank bolt? My 6pt broke and spun on the bolt when I had the breaker propped against the ps frame... now nothing works... rounded off bolt.
dangit. <img src="/forums/images/graemlins/scared.gif" alt="" />
Dave
86 4Runner, 22R-EB
Re: Crank Bolt [Re: drainsbe] #857847 01/05/08 08:04 PM
4Crawler Offline
Some options:
1. Weld a nut to the head of the bolt.
2. Pound a slightly smaller sized socket onto the stripped bolt head, or get one of those bolt-remover sockets.
3. Use a cutoff wheel to notch the washer and bolt flange and use a hammer and chisel to break the bolt loose with the chisel in one of the notches.
Re: Crank Bolt [Re: drainsbe] #857848 01/05/08 08:42 PM
A
atoyot Offline
Air hammer with a sharp chisel bit, and an air regulator to keep it under control, and to use a minimum of force.
Re: Crank Bolt [Re: 4Crawler] #857849 01/05/08 08:43 PM
drainsbe Offline OP
Thanks Roger!
I knew I should have asked for a welder for Christmas
I went and got a 6pt 3/4 socket... tapped it on w/a hammer. Nice and snug. Wish me luck. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Dave
86 4Runner, 22R-EB
Re: Crank Bolt [Re: drainsbe] #857850 01/05/08 09:02 PM
drainsbe Offline OP
the 6pt 3/4 snapped like it was nothin... <img src="/forums/images/graemlins/scared.gif" alt="" /> luckily had a cheapy NorthernTool 6pt 19mm impact that seems a little under sized. Bumped the starter w/that on it and it came right out. <img src="/forums/images/graemlins/notooth.gif" alt="" /> Now on to the TC cover & headgasket replacement.
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Dave
86 4Runner, 22R-EB
Re: Crank Bolt [Re: 4Crawler] #857851 01/06/08 09:17 AM
V
v8yota Offline
[quote]Some options:
3. Use a cutoff wheel to notch the washer and bolt flange and use a hammer and chisel to break the bolt loose with the chisel in one of the notches. [/quote
never pound nothing on the crack,,you can destroy thr thrust on the crank
Re: Crank Bolt [Re: v8yota] #857852 01/06/08 08:00 PM
OOP'S Offline
Here is another, by cutting the flange it relives the pressure and you can remove it with your fingers.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Crank Bolt [Re: OOP'S] #857853 01/06/08 11:24 PM
Adam F Offline
On a related note, are crank bols on all engines supposed to be replaced every time you remove them? I know this is the case with the 5vzfe, but not sure on other engines.
97 4R, stock, daily driver
Re: Crank Bolt [Re: Adam F] #857854 01/07/08 02:11 AM
OOP'S Offline
I would!!!!!!
David Fritzsche
Roseville, CA
Re: Crank Bolt [Re: OOP'S] #857855 01/13/08 03:01 PM
Stevie Offline
My crankbolt was made in 1979. Pulley was removed numerous times. Maybe I'm lucky, but I do use the right tools on it, as well as the proper torque too. <img src="/forums/images/graemlins/wink.gif" alt="" />
'80 4X4 Longbed
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.009s) Memory: 0.6321 MB (Peak: 0.7401 MB) Data Comp: Off Server Time: 2026-07-15 12:47:25 UTC
