4Runner Rear Window? #858017 01/06/08 09:28 PM
rondog Offline OP
I was just in the garage ops checking my 4Runner (1987) rear window. It will roll down all except the last 3 or 4 inches. Looked in the tailgate, but seen no obstructions. What am I missing?? Thanks Ron
Re: 4Runner Rear Window? [Re: rondog] #858018 01/07/08 12:13 AM
TRDSR5 Offline
Likely teeth.
Teeth on the crescent gear of the regulator. The little gear on the motor meshes with the teeth on the crescent shaped peice of steel, when the it gets to a missing (or worn down) tooth it stops
Turn LEFT to go RIGHT
Thudump!....What was that daddy? Ran over a Honda, go back to sleep sweety.
Re: 4Runner Rear Window? [Re: TRDSR5] #858019 01/07/08 01:08 AM
rondog Offline OP
Thanks for the info. I will check it. I spayed everything down with kroil and ran a screwdriver through the track and it goes down now. It has been sitting for awhile without being used, so I am sure it is all crusted up. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 4Runner Rear Window? [Re: rondog] #858020 01/07/08 02:34 AM
hodgepodge79 Offline
It's really pretty simple to take off the pannels on the tailgate and take a look at everything. You can lube up the bottom (horizontal) track where the plastic rollers/wheels go back an forth.
Mine kept having problems, so when I took it apart, I found that one of the wheels was gone, and the other was nearly gone. I got a replacement form the wreck yard.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5997 MB (Peak: 0.6548 MB) Data Comp: Off Server Time: 2026-06-10 07:18:17 UTC
