Best Distributor Cap/Rotor #858187 01/07/08 03:30 PM
6
67shagster Offline OP
Its tune up time. I guess most people might say "Toyota" parts only. Since other parts stores are right in my backyard, i was just wondering about other brands (beck arnley, bosch, niehoff etc.) im going with HGK plugs.
Thanks in advance.
Re: Best Distributor Cap/Rotor [Re: 67shagster] #858188 01/08/08 02:58 AM
OOP'S Offline
OEM and while you are at the dealer pick up a set of plugs also.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Best Distributor Cap/Rotor [Re: OOP'S] #858189 01/08/08 06:07 AM
6
Well, i guess i will get everything (including the NGK's) from the dealer seeing as how i need the big 0 ring for the distributor. Thanks anyway. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Best Distributor Cap/Rotor [Re: 67shagster] #858190 01/09/08 01:36 AM
A
aptech Offline
toyota parts
alway had good service and they are cheaper than walking into the dealer and most other places for yota oem parts
Re: Best Distributor Cap/Rotor [Re: aptech] #858191 01/09/08 03:01 PM
Staceman Offline
toyota parts
X2, I use these for just about anything Toyota, from oil filters, bearings, and even new REAL carpet kits for the Camry. 1/2 the cost of cheezy aftermarket.
Re: Best Distributor Cap/Rotor [Re: Staceman] #858192 01/10/08 05:31 AM
W
woodmaster9 Offline
Some of us have yotas that are so old that the dealers no longer stock parts. My (new) truck is an '80. What distrib cap / rotor would you guys recommend when you can no longer get the oem's? Briefly looking, my choices are Standard, Bosch, and one described as "Asian". (Unless "Asian" is a company name????)
Re: Best Distributor Cap/Rotor [Re: woodmaster9] #858193 01/10/08 05:43 AM
kewlynx Offline
It's Aisin. That's essentially OEM; our stock carbs are Aisin, as are the hubs. <img src="/forums/images/graemlins/wink.gif" alt="" />
Stick with NGK plugs from NAPA. The Fram cap and rotor I've never had trouble with. You should still be able to get OEM plug wires from the dealer, but gawd--$$$$. OEM oil filter or NAPA's gold filter will work for you too.
Don't fret-- there's a couple '80 owners around here. <img src="/forums/images/graemlins/notooth.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6177 MB (Peak: 0.6913 MB) Data Comp: Off Server Time: 2026-06-10 07:16:08 UTC
