Re: Different manual transmission for the 3.0L 6G72? [Re: ES_97Sport] #1106485 09/24/21 09:55 PM
L
LTChip Offline
Resurrecting this thread....anyone have a source on used, new or rebuild kits for a 1989 V6 Manual Dodge Raider?
Yellow 1989 Gen 1 SWB V6 5sp Dodge Raider
Re: Different manual transmission for the 3.0L 6G72? [Re: LTChip] #1106489 09/27/21 06:17 PM
Re: Different manual transmission for the 3.0L 6G72? [Re: ES_97Sport] #1106496 09/28/21 08:14 PM
BrooklynOpus Offline
My transmission guy here in Brooklyn suggested VividRacing.com
I'll see if I can find his note.
I too have a 1989 MT Raider. At the moment, the tranny sounds like a rock tumbler.
I am hoping its just a bad throwout, or clutch part came loose.
Getting chirping now - need to deal with it asap.
Noise goes away when clutch pedal is in.
Shifts clean, no slipping. And i noticed at about 2k rpm the noise settles.
1989 Monty 3.0 AT
1989 Raider 3.0 MT
Re: Different manual transmission for the 3.0L 6G72? [Re: ES_97Sport] #1106498 09/30/21 12:34 PM
Found the note:
vividracing.com
bearing/seal/synchro kit
model # zmbk189ws
I haven't confirmed, so I leave that to you.
1989 Monty 3.0 AT
1989 Raider 3.0 MT
Re: Different manual transmission for the 3.0L 6G72? [Re: LTChip] #1106499 10/01/21 11:50 AM
All the bearings and seals are standard parts available most anywhere. Do you really need syncros? Or just told you want them?
Re: Different manual transmission for the 3.0L 6G72? [Re: ES_97Sport] #1106500 10/02/21 12:17 PM
Hey Charlie,
I am convinced I have a clutch problem.
Tranny guy is convinced I have a tranny problem.
And of course, his take is while in there replace everything.
Which isn't the worst advice, when paying for labor.
I am replacing clutch myself soon and going from there.
Eric
1989 Monty 3.0 AT
1989 Raider 3.0 MT
Re: Different manual transmission for the 3.0L 6G72? [Re: ES_97Sport] #1106501 10/03/21 07:43 AM
That is one of the last persons I would trust. Vivid racing has nothing for these vehicles.
You really need to have a valid analysis of what is wrong and from what I read here, trust your instincts.
The only aspect of that transmission I am aware of having a problem is fasteners loosening on the rear mainshaft bearing retainer. Allows the mainshaft to move fore-aft with throttle changes in all but 4th gear.
If your transmission shifts well, do not break it.
If it has a bearing problem, that will be different in each gear and differing throttle.
A clutch release bearing, noise generally changes with foot on or off.
I would not pay thousands if it is just a $20 TO bearing.
The real decision for clutch work, pull the engine or the transmission. I think the engine is easier on that rig.
That transmission/Tcase is fargging heavy and does not want to sit on a jack. Because of the Tbar crossmember the trans needs to come forward.
Re: Different manual transmission for the 3.0L 6G72? [Re: ES_97Sport] #1106505 10/04/21 08:14 PM
Thanks Charlie!
1989 Monty 3.0 AT
1989 Raider 3.0 MT
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6308 MB (Peak: 0.7301 MB) Data Comp: Off Server Time: 2026-10-24 02:36:51 UTC
