how to get the fan clutch off the water pump on a 2000/4.0l? #858950 01/10/08 04:21 AM
Z
zacaroo Offline OP
I have searched for a tool that was made for this but can't fine one that fits. seems like a tool that would use the 4 bolts on the pully would be the answer, has anyone found and used a tool that works?
00 wrangler
85 truck, 22r, 4x4
06 KLR650
clean it only if you plan on working on it!
Re: how to get the fan clutch off the water pump on a 2000/4.0l? [Re: zacaroo] #858951 01/22/08 08:06 PM
Z
zacaroo Offline OP
wow, I guess this is a stumper! well as an update I did get this apart, ended up making my own tool. maybe i should patent this thing! ill try to get some pictures up on here of what I made.
00 wrangler
85 truck, 22r, 4x4
06 KLR650
Re: how to get the fan clutch off the water pump on a 2000/4.0l? [Re: zacaroo] #858952 01/23/08 04:49 AM
fred1980 Offline
Flathead screw driver to "jam" between one of the screws and the fan clutch shaft (after loosening said screw of course) and a wrench always worked for me...
Fred R.
97 ZJ, 5" Long Arm Lift, Beadlocked 35's, 231/D300 Doubler, Locked Front & Rear (Narrowed HP D44 & F8.8), ARB Bull Bar & 9K winch, 1-Ton Hydro-assist steering, "Custom" body work and some other goodies... PICS
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5916 MB (Peak: 0.6442 MB) Data Comp: Off Server Time: 2026-07-09 22:01:59 UTC
