91 Wrangler Transmissions #859724 01/14/08 04:02 AM
kwcraft Offline OP
Just purchased this 91 that needs tranny work. First and foremost it goes in reverse just fine, Forward slips bad but sometimes engages.
Heres the specs on the rig:
91 Jeep Wrangler
6Cyl 4.0L High Output engine
Unsure what the tranny is just yet
When I picked it up, we added some tranny fluid (most of which poured straight to the ground) the little that must have got in did give us a little forward, but not enough to get it up the trailer.
So now heres my thoughts:
1. Filter and pan gasket need changed. We did this once with a buick with the same issue and it fixed it.
2. The filler tube is cracked OR not fully seated in the tranny? possibility?
3. Tranny is burned out, need a new one.
I had a lead on a tranny, but after doing a little digging think that it will not fit my wrangler. It comes from a 91 Cherokee.
Any suggestions?
Thanks,
Ken
91 Jeep Wrangler 6Cyl 4.0HO
94 Suzuki Sidekick 1.6L 4x4 JLX
01 Dodge Ram 5.2L 4x4
Re: 91 Wrangler Transmissions [Re: kwcraft] #859725 01/14/08 04:13 AM
Brown81CJ5 Offline
I believe that BJ was correct in that it is a 32RH. But this page says that those were used in 92-95. But the site also does not list one for a 91 YJ.
web page
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: 91 Wrangler Transmissions [Re: Brown81CJ5] #859726 01/14/08 04:48 AM
kwcraft Offline OP
Yeah the guy that had the other tranny told me that it was T999 that I needed.
I guess the only way to find out is to pull the jeep onto the pad and get under there and look. I'll try to do that tomorrow.
I do have a lead on a 91 Wrangler transmission, are there any changes during the year that I should be cautious of? Was there a specific date when they changed from 21 to 23 teeth on the spline? (If thats the correct verbage).
Ken
Re: 91 Wrangler Transmissions [Re: kwcraft] #859727 01/14/08 05:07 AM
Brown81CJ5 Offline
Ah...the site does list the 91 as a T999. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Gun it and run it!
Re: 91 Wrangler Transmissions [Re: Brown81CJ5] #859728 01/14/08 05:46 AM
BigJim Offline
Ok I went to that site and I was incorrect I guess... Anyways the 999 is a really good tranny. I think it was used in some v8 applications.. I'd be looking to rebuild it.
Re: 91 Wrangler Transmissions [Re: BigJim] #859729 01/14/08 06:29 AM
kwcraft Offline OP
Gotta love craigslist.
Found someone with a 91 Wrangler willing to part with his working tranny (Still running in the rig) and a steering column from a 93, and he's willing to barter. Should be thursday or saturday and I'll have em.
Figure I'll put the working tranny up into my jeep, and take the other one and send it to the shop for a looksee. If its worth spending a few hundred bux overhaulin, I may just to have a spare laying around.
Ken
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6089 MB (Peak: 0.6791 MB) Data Comp: Off Server Time: 2026-07-15 14:42:46 UTC
