Hitch mounted spare tire carrier/what do you think? #859769 01/14/08 06:37 PM
damitboy Offline OP
Has anyone tried one of these to get the spare out of the cargo area? The only thing it seems to be missing is a hinge to fold it down to open the rear hatch. That would be an easy fab. though. hitch spare mount
94 XJ 2 Door/2.5/5 SPD/4 WD
Re: Hitch mounted spare tire carrier/what do you think? [Re: damitboy] #859770 01/14/08 10:17 PM
BigJim Offline
Never saw one of those in actual use..The rattleing/banging noise of the thing would drive me bonkers. But it would free up space inside on a trail ride.
Re: Hitch mounted spare tire carrier/what do you think? [Re: BigJim] #859771 01/14/08 10:32 PM
Brown81CJ5 Offline
It says it is only rated for 100 lbs. So if using it on a trail ride, if your tire weighs i.e. 40lbs...when the rear of the rig comes down off a bump or something, that 40lbs could easily turn into 100+ lbs cause of the downward motion.
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Hitch mounted spare tire carrier/what do you think? [Re: Brown81CJ5] #859772 01/15/08 02:03 AM
Bigbird79 Offline
It does say a max tire weight of 100 lbs, not a max tire force of 100 lbs, so I would have to believe they are referring to lbm (mass) not lbf (force), which they can't really control. Either way, I agree with Jim, the noise would drive me batty, I spend a fair amount of time eliminating rattles and vibrations in my vehicles, I wouldn't want to intentionally add one.
Sean
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: Hitch mounted spare tire carrier/what do you think? [Re: Bigbird79] #859773 01/15/08 02:33 AM
DBL_DTY97TJ Offline
I don't think it would be a problem. No different than an excess cargo carrier, which plugs into the hitch and I've used plenty. It really doesn't make noise. Maybe mine's just a snug fit w/ all the rust, but I've never heard it bouncing along down the beach...Maybe my tires and radio drown it out. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD. smile
Re: Hitch mounted spare tire carrier/what do you think? [Re: DBL_DTY97TJ] #859774 01/15/08 04:33 AM
BigJim Offline
This thing stands up above the hitch with a 50lb tire in it.. It will jump back and forth and make all kinds of noise..
I have a deer feeder that mounts in my hitch and weighs bout the same.. I have a stiff wire with a turn buckle on it to tie the feeder down and help shut it up..
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6091 MB (Peak: 0.6788 MB) Data Comp: Off Server Time: 2026-06-17 13:28:24 UTC
