WTK: 86 4runner dudes. the digital clock is always on.any culprits? #859826 01/14/08 10:34 PM
Rudi Offline OP
It started about last month and it is always on. If left on for a while it drains the battery.
Just wondering if its the clock itself or ??
Any suggestions on what to check?
thanks
Re: WTK: 86 4runner dudes. the digital clock is always on.any culprits? [Re: Rudi] #859827 01/14/08 11:36 PM
4Crawler Offline
Back of the clock should have one wire that is constant 12 volts (red-white - for the time keeping) and one that is switched 12 volts (red-green - for the display). Test the switched line to see if it is staying on. If so, trace that wire back to where it comes from. Normally powered off the cigarette lighter circuit/fuse, so perhaps that circuit has been modified to stay hot all the time or the relay that controls it is stuck on.
Re: WTK: 86 4runner dudes. the digital clock is always on.any culprits? [Re: 4Crawler] #859828 01/15/08 12:09 AM
Rudi Offline OP
Thanks man....any chance you can give me information where the relay is for that circuit?
I'm guessing its near the fuse panel?
Re: WTK: 86 4runner dudes. the digital clock is always on.any culprits? [Re: Rudi] #859829 01/15/08 12:16 AM
4Crawler Offline
Factory Service Manual (link at top of forum) has a wiring diagram in it. I think the cig. lighter may be fed from the ACC output of the ignition switch. May or may not have a separate relay.
PHP: 7.4.33 Page Time: 5.017s Queries: 15 (5.014s) Memory: 0.6027 MB (Peak: 0.6581 MB) Data Comp: Off Server Time: 2026-10-24 03:20:12 UTC
