Spare Tire Mechanism Jammed #859950 01/15/08 02:14 AM
Rodayo Offline OP
All -
Does anyone have an idea on how to unjam the spare tire lowering mechanism underneath a 2004 Rodeo? I lowered my tire the other day to do some work underneath then raised it again. So far just fine. When I went to lower it again, however, it would not move. It is nearly impossible to see up under there and the shop manual doesn't show much. Any help would be appreciated.
- Jim
1996 Rodeo - 3.2L, 5sp., ARB Bull Bar, Rancho 9000x, Eclipse sound
2004 Rodeo - 3.5L DI, Auto
Re: Spare Tire Mechanism Jammed [Re: Rodayo] #859951 01/15/08 02:46 AM
holger Offline
I had this issue a couple times.
I was shaking the tire from underneath, and spraying the WD40 to the upper area of the tire. It helped.
Oleg
Deceased Rodeo'02 4WD.
Re: Spare Tire Mechanism Jammed [Re: holger] #859952 01/15/08 03:14 AM
W
Wayne Offline
This is common to many vehicles. Lots of crud under there.
Two people help. One turns the lever back and forth to raise/lower it, the other is underneath going "jigglie-jigglie" on the tire.
Or if you're alone and in the middle of nowhere, or if you don't want to get under the vehicle because it's snowy and et, kick the spare while you turn the shaft back and forth.
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: Spare Tire Mechanism Jammed [Re: Rodayo] #859953 01/15/08 06:07 AM
kewlynx Offline
This is common on Toys too; you'll have to work it like the guys said.
This is a spring/fall maintenance area that I always suggest to go with tuneup and stuff. PB Blaster (NAPA) or Aerokroil are good penetrants. Once you get the mechanism down, flush the area as best you can, or take a parts brush to it. Soak with penetrant of choice, run up and down once or twice without the tire. Swab mechanism with antiseize compound. Clean out tire, check air pressure, make sure the valve stem is where you can reach it any time, and run 'er back up for the next 6 months. <img src="/forums/images/graemlins/cheers.gif" alt="" />
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6037 MB (Peak: 0.6597 MB) Data Comp: Off Server Time: 2026-10-22 02:15:40 UTC
