amc head #860019 01/15/08 04:39 PM
binx Offline OP
I just received my new amc head and i had assumed that it would be complete minus the cam but it was also missing the rockers. Is there any reason to worry about using the old rockers(they seemed to be functioning, but i haven't pulled it apart yet), or should i just order the amc rockers. Also, i am assuming the amc rockers are the same thing as the stock part, right.
thanks
2000 amigo ironman, 4" suspension 1" body lift on 33's with 4.77 gears, tera lows, and no-slip locker.
Re: amc head [Re: binx] #860020 01/16/08 03:27 AM
Richard Saylor Offline
Just swap everything over from your old head assuming they're in good shape. That's what I did when I did mine. You could have also ordered the head complete with everything, but it was more expensive and not worth it, IMO.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: amc head [Re: binx] #860021 01/16/08 08:45 AM
Trooper-san Offline
I too swapped the cam and other stuff from the oem head onto the AMC. Mine came with new valves and springs,as I recall, but nothing more. The valves were a necessity-- look at my pictures listed below.
Switching things over is easy enough. Just plan the job ahead of time, go slow, and think about what you're doing.
1989 Trooper, 2.6
1989 Trooper, 2.8
1992 Ford F-350, 7.3
My Photos
Re: amc head [Re: Trooper-san] #860022 01/16/08 07:12 PM
binx Offline OP
thanks guys, I will hopefully be getting started soon.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5990 MB (Peak: 0.6548 MB) Data Comp: Off Server Time: 2026-10-26 21:02:25 UTC
