strange 3.0 electrical problem
#860229
01/16/08 03:42 AM
A few weeks back I sprung a coolant leak on the large pully by the timing belt. I was out of town and took it to a shop. Several weeks later after they finally found the problem I picked it up an immeadiatly noticed that it would sputter between 1500-2500 rpm. It then started to lurch when I was driving it and threw code 11 (momentary interuption in ECU power supply) for a split seconed.
The coil wire is arching (I have non OEM wires)even when I replaced the coil wire with a new one. I advanced the timing a bit (I dont have my timing light with me I just moved it to see what would happen) and it runs better but not great and still keeps throwing this damn code.
Any Ideas?
Re: strange 3.0 electrical problem
[Re: lostone]
#860230
01/16/08 04:05 AM
So what did they tear down to fix your problem?
[Re: kewlynx]
#860231
01/16/08 04:13 AM
I guess they took off the timing belt and put it back on and they must have messed with the distributor Beacuse the timing was retarded quite a bit.
[Re: lostone]
#860232
01/16/08 04:57 AM
The cams might be off a tad; we have a 3.4 timing belt article in the Yota section above in the header you might give a read to see what I'm referring to. If they pulled the belt without finding TDC beforehand, it doesn't help.
We also have a '93 FSM in a sticky in this section where you can look at the troubleshooting tree for the code, if you haven't already done so.
Hopefully some of these other 6-banger guys will chime in too.
[Re: kewlynx]
#860233
01/16/08 05:17 AM
I was afraid that they may have gotton the cams off a bit. Its easy enough to do. I actually did it once when I rebuilt the motor. What about the trouble code?
Oh BTW I'm about a hundred miles away from my shop, is it okay to drive it that far with the cams off?
[Re: lostone]
#860234
01/16/08 05:36 AM
I'd verify the cams are set up first, then chase that code, if nothing else, to just get the timing eliminated.
It's a non-interference engine, so your call to drive it, really.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6128 MB (Peak: 0.6825 MB) Data Comp: Off Server Time: 2026-06-07 04:36:53 UTCValid HTML 5 and Valid CSS
