strange 3.0 electrical problem #860229 01/16/08 03:42 AM
L
lostone Offline OP
A few weeks back I sprung a coolant leak on the large pully by the timing belt. I was out of town and took it to a shop. Several weeks later after they finally found the problem I picked it up an immeadiatly noticed that it would sputter between 1500-2500 rpm. It then started to lurch when I was driving it and threw code 11 (momentary interuption in ECU power supply) for a split seconed.
The coil wire is arching (I have non OEM wires)even when I replaced the coil wire with a new one. I advanced the timing a bit (I dont have my timing light with me I just moved it to see what would happen) and it runs better but not great and still keeps throwing this damn code.
Any Ideas?
Re: strange 3.0 electrical problem [Re: lostone] #860230 01/16/08 04:05 AM
kewlynx Offline
So what did they tear down to fix your problem?
**ubi apis- ibi salus**
Re: strange 3.0 electrical problem [Re: kewlynx] #860231 01/16/08 04:13 AM
L
lostone Offline OP
I guess they took off the timing belt and put it back on and they must have messed with the distributor Beacuse the timing was retarded quite a bit.
Re: strange 3.0 electrical problem [Re: lostone] #860232 01/16/08 04:57 AM
kewlynx Offline
The cams might be off a tad; we have a 3.4 timing belt article in the Yota section above in the header you might give a read to see what I'm referring to. If they pulled the belt without finding TDC beforehand, it doesn't help.
We also have a '93 FSM in a sticky in this section where you can look at the troubleshooting tree for the code, if you haven't already done so.
Hopefully some of these other 6-banger guys will chime in too.
Re: strange 3.0 electrical problem [Re: kewlynx] #860233 01/16/08 05:17 AM
L
lostone Offline OP
I was afraid that they may have gotton the cams off a bit. Its easy enough to do. I actually did it once when I rebuilt the motor. What about the trouble code?
Oh BTW I'm about a hundred miles away from my shop, is it okay to drive it that far with the cams off?
Re: strange 3.0 electrical problem [Re: lostone] #860234 01/16/08 05:36 AM
kewlynx Offline
I'd verify the cams are set up first, then chase that code, if nothing else, to just get the timing eliminated.
It's a non-interference engine, so your call to drive it, really.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6122 MB (Peak: 0.6819 MB) Data Comp: Off Server Time: 2026-11-02 21:48:03 UTC
