coolent leak from the rear? #860615 01/17/08 09:23 AM
8
87toy Offline OP
I just bought this 87 Toyota pickup 2x4, its a 22r 4 speed, there is a small coolant leak coming from the rear of the engine, I cannot see where? Hopefully its not a headgasket? maybe its the transmission coolant line, ill have to look into it more. The truck will need a new clutch soon so i want to fix this while im at it. any advise is greatly appreciated
Thanks Joe
Under construction.
Re: coolent leak from the rear? [Re: 87toy] #860616 01/17/08 10:45 AM
Adam F Offline
If its green coolant, its not transmission fluid. Trans fluid is red.
97 4R, stock, daily driver
Re: coolent leak from the rear? [Re: Adam F] #860617 01/17/08 03:14 PM
4x4runner Offline
If it is a 4 or 5 speed, it will not have coolant lines. Check your heater hoses where they enter the firewall.
Re: coolent leak from the rear? [Re: 87toy] #860618 01/17/08 04:53 PM
Stevie Offline
If it's coolant, there is a plate bolted to the end of the cylinder head that could possibly leak. Is there any oil in your radiator, or is your engine "making" oil? How bad is the leak?
'80 4X4 Longbed
Re: coolent leak from the rear? [Re: Stevie] #860619 01/17/08 05:07 PM
Staceman Offline
Engine drain plug tight?
Under the exhaust manifold, driver side, rear of engine.
You should be able to check it from under the truck.
Re: coolent leak from the rear? [Re: Staceman] #860620 01/17/08 06:18 PM
8
87toy Offline OP
it leaves a small puddle overnight, quarter size to about a 3 inch circle size, the previous owner said there is a hard heater hose that runs behind the back of the block that may be it. No oil in it, and it is greenish.
Thanks for the info, tomorrow ill crawl under there and try to find it. Joe
Under construction.
Re: coolent leak from the rear? [Re: 87toy] #860621 01/18/08 12:54 AM
KB1 Offline
Check your heat control valve. It may be dripping onto the back driver's side corner of the head and run down making it seem like it was coming from the rear of the engine. Mine did. Boy, they're pricey too!! <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: coolent leak from the rear? [Re: KB1] #860622 01/18/08 02:13 AM
kewlynx Offline
Yep, hard line wraps around the back; there's also the plate Stevie mentions. If you can't see it right away, lay a clean piece of cardboard under there and let it sit n drip. Go from there.
**ubi apis- ibi salus**
Re: coolent leak from the rear? [Re: kewlynx] #860623 01/19/08 08:21 AM
8
87toy Offline OP
i found it, just a lose hose clamp on the rear heater hose to the cab, but now when i give it gas i can here water running, sounds to be through the heater core. not to worried about it thow, i need to repalce the heater and ac controls thow.
Joe
Re: coolent leak from the rear? [Re: 87toy] #860624 01/19/08 08:35 AM
kewlynx Offline
Cool. Why do you need to replace the other stuff?
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6381 MB (Peak: 0.7606 MB) Data Comp: Off Server Time: 2026-06-07 07:27:47 UTC
