Re: coolent leak from the rear? [Re: kewlynx] #860625 01/20/08 06:13 AM
8
87toy Offline OP
because most of the knobs are brokin off,there is a big hole in it as well, and the one that slids from hot to cold is jsut missing, and its stuck someplace in the middle. i will have to go to the junk yard and replace the whole peice. hopefully its not a huge pain.
i also need a rear window because there is none, and the shell has no window to the cab, and the exaust hangers are missing the rubber peices so it rattles really bad. and i think i need a new clutch that or i need to have the clutch cylinders bled. it also needs new rotors cause the breke peddle pulses really bad.
ok thats my list, <img src="/forums/images/graemlins/frown.gif" alt="" />
Under construction.
Re: coolent leak from the rear? [Re: 87toy] #860626 01/20/08 06:24 AM
87Toy4x4 Offline
i think the "water running" sound is air in your lines b/c you did not bleed the air out of the system after you fixed the leak.
Re: coolent leak from the rear? [Re: 87Toy4x4] #860627 01/20/08 06:49 AM
8
87toy Offline OP
Monday im going to have it flushed. i popped the radiator cap and its brick red, for all i know the thermostat is missing and thats why it does that, its only whne i give it gas from idel. good times
Under construction.
Re: coolent leak from the rear? [Re: 87toy] #860628 02/22/08 07:29 AM
8
87toy Offline OP
i forgot about this thread,The water running noise is because my heater control valve is stuck in the just barley open place, ive since fixed everything, re-roded radiator, new pump hoses, heater controls etc etc, only place i can find a good heater control valve is at the dealer, 91 bucks woo hoo good times, after i do my clutch monday, thats next.
Under construction.
Re: coolent leak from the rear? [Re: 87toy] #860629 02/22/08 10:37 PM
MAC Offline
I got a good heater control from this guy cheap ($15 if I remember correctly). Toyota Foolish is the Co. name. Bruce: [email]sunlight714@yahoo.com.[/email] 828-626-3227. Also try id mmccul3797 on ebay. Got good cheap stuff from him also.
Re: coolent leak from the rear? [Re: MAC] #860630 02/23/08 08:29 AM
kewlynx Offline
Dealt with both of 'em. Bruce is a gent. <img src="/forums/images/graemlins/kewl.gif" alt="" />
**ubi apis- ibi salus**
Re: coolent leak from the rear? [Re: 87toy] #860631 02/23/08 05:27 PM
toyrunner Offline
Try the Toy dealer in Valencia.
They offer a TLCA discount and are far cheaper than some urban dealerships.
I found the heater valve at Ventura Toyota for $48 last year for my 85 4Runner.
Shop around a bit as all dealers have different prices.
I have dealt with Toyota Foolish before. Good response time and great used parts.
Danny
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6246 MB (Peak: 0.7147 MB) Data Comp: Off Server Time: 2026-06-07 07:25:47 UTC
