2005 4Runner limited 4wd v6 rotor thickness: #860938 01/18/08 04:13 PM
0
05_4Runner Offline OP
Does anyone know what the minimum thickness is and when it's recommended to change them?
Re: 2005 4Runner limited 4wd v6 rotor thickness: [Re: 05_4Runner] #860939 01/21/08 02:32 AM
Adam F Offline
You would need a FSM (Factory service manual) for a 03+ 4Runner. Closest I could find was a Tacoma manual for the same year. It says 28mm standard thickness, 26mm minimum.
Dont have them turned more than once. And if you get vibration during braking, they are warped, replace them.
97 4R, stock, daily driver
Re: 2005 4Runner limited 4wd v6 rotor thickness: [Re: Adam F] #860940 01/21/08 10:30 PM
0
Thanks. I've had them turned 1x when they were warped from sitting for many months when it only had 2000 miles. There is no vibrating now, but should I need to replace the pads I'm going to have to rough them a little so it will adapt to the pads from what I have read.
Re: 2005 4Runner limited 4wd v6 rotor thickness: [Re: 05_4Runner] #860941 01/21/08 10:37 PM
Adam F Offline
I've done countless pad changes without touching the rotors, and never had a problem. Heck, on my old Honda I wore the pads down to bare metal, and it ate into the rotor, leaving a big gouge in the rotor. I slapped some new pads on it because I couldnt afford rotors at the time, and went to inspect them a week later and the rotor was like new again.
If it makes you feel better, hit the rotor with some sand paper.
Re: 2005 4Runner limited 4wd v6 rotor thickness: [Re: Adam F] #860942 01/21/08 10:48 PM
0
Good to know. Thanks!
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6060 MB (Peak: 0.6704 MB) Data Comp: Off Server Time: 2026-05-25 14:55:48 UTC
