Jeep won't idle smooth #861045 01/18/08 10:18 PM
9
93jeepcher Offline OP
I have a 1993 Jeep Grand Cherokee V6 4.0, that idles rough. When i put it in gear the rough idle is felt even more. I recently had to put a new CPS in when it stopped running. Now it runs, but not smooth. People told me that a cps either works, or doesn't. I also did plugs, rotor, cap, wires, and fuel filter. There is no check engine light on either. I am out of ideas. Any advice would be greatly appreciated.
Thank You
Re: Jeep won't idle smooth [Re: 93jeepcher] #861046 01/19/08 12:04 AM
BigJim Offline
What you have is an inline 6 cylinder...NOT a V-6.
That said the idle is mostly controlled by the IAC (idle air control) This is at the throttle body. It is usual to clean both the IAC and the throttle body to improve the idle.. You MAY need another IAC if the idle doesn't improve.
Do you have the stock air cleaner on that Jeep? The cold air kits usually cause idle problems as they allow too much dirt to enter the engine.
Re: Jeep won't idle smooth [Re: BigJim] #861047 01/20/08 02:25 AM
playinmud Offline
ever have the injectors cleaned? that smoothed up my rough idle, along with a cleaning of my throttle body and IAC
WHEN THE ROAD ENDS, THE FUN BEGINS
97 sahara, 4in skyjacker lift, 33in tires, borla header & catback, 10in subs
Re: Jeep won't idle smooth [Re: 93jeepcher] #861048 01/25/08 09:04 AM
rvdjr Offline
check for vacuum leaks, or better yet replace all vacuum lines. the factory ones are probably getting a little old. an easy check it to plug all vacuum ports well and then test it. if it was a vacuum leak this will prove it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5998 MB (Peak: 0.6551 MB) Data Comp: Off Server Time: 2026-06-23 11:14:42 UTC
