tire size #861274 01/19/08 10:15 PM
mrvoodoodaddy69 Offline OP
anyone running p285/75 16's ?
any issues?
i would like to go to that says but all tire shops
are telling me that they are too big.
i am running p265's now and looks to me that they should
be ok.
Re: tire size [Re: mrvoodoodaddy69] #861275 01/20/08 03:10 AM
garym Offline
The kid who runs the local drive up coffee shop has them on his with no mods. He says they rub when turning sharp.
1997 T-100 4X4 Xcab,Warn Hubs
02 Camry LE
2008 Yaris
Re: tire size [Re: mrvoodoodaddy69] #861276 01/20/08 05:36 AM
wsquaredodie Offline
I run 265's and under hard turns they hit the mud flaps. Not by much though. 285's - no way w/o mods
trafdlo
Re: tire size [Re: wsquaredodie] #861277 01/20/08 06:45 AM
Creeper Offline
I run 285/75's with about 2.5" of lift and I still get a slight rub at full lock.
'97 T100 SR5 XCab 4WD
TRD SC ~ ARB ~ FWC
'85 FJ60 Landcruiser
4E9 ~ locked ~ 33's
Re: tire size [Re: Creeper] #861278 01/21/08 01:19 PM
thanks for the info, guess im waiting for anything
bigger til i get off my arse and do some mod's.
just trying to figure out if i want to tackle
a stright axles set up or not.
thanks again!
Re: tire size [Re: mrvoodoodaddy69] #861279 01/21/08 06:30 PM
Brew Offline
It'll take lift and wheel offset/backspacing.
I'm running 255/85R16s(33x10x16) with a 2" body lift and Eagle Alloy 16x7 rims at 4.25" backspacing(+8mm offset). My tires rub slightly on my fender liners at full lock but nowhere else. I did remove my front mud guards. The default backspacing of my original 16x7 Toyota Alloys was 4.625"(+15mm offset). My Eagles with 4.25" backspacing have pushed my wheels outward another .375" or 3/8" and I went with tires about 1/2" narrower though 2" taller @ 32.7".
285s are almost an inch wider than the 265/70s I had stock. There also 32.7" to 33.1" tall versus 30.6" on the 265/70s. You might be able to crank the torsion bars and go with a lower backspaced wheel (~4") but it would likely rub somewhere. You'll also lose the plush ride if you crank those T.bars very much at all. Brew <img src="/forums/images/graemlins/cheers.gif" alt="" />
98 T100 SR5 4x4 3.4L auto, TRD Goodies, Bilsteins, engine/TC skids, 2" body/d.train lifts, F/R ARBs, 4.56 R&Ps, Aisin hubs, 255/85R16 Dunlop Rover RVXTs (street), 16x7 +8mm offset wheels, custom bumpers, Warn M8000, Master-pull synth. line
Re: tire size [Re: Brew] #861280 02/02/08 05:57 AM
TimmiT Offline
Would wheel adaptors be reasonable to use? I was looking at the same size tire, and a 2 inch body lift. To help the clearance on the turs, I was thinking a 1 inch wide adaptor, the kind that would bolt onto the existing studs, and have new to bolt the wheels onto.
Any opinions on the adaptors to make the tire size work?
Re: tire size [Re: TimmiT] #861281 02/02/08 04:14 PM
Brew Offline
I looked at adapters a long time ago and thought they might be okay. However I finally decided against it for my truck, as I didn't want to induce any additional pressure on the existing studs. I sold my OEM alloys to offset the new wheel expense. I've read that lots of people run them so hopefully one of our more knowledgeable members will reply. Sorry I'm not much help. Brew <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6237 MB (Peak: 0.7065 MB) Data Comp: Off Server Time: 2026-06-22 06:14:43 UTC
