95 rodeo front axle swap #861909 01/22/08 12:09 AM
O
offrodeo95 Offline OP
is there any other front axle that would work beside the 73-79 jeep wagoneer axle. there are hard to find with all the right specs
95 isuzu rodeo, 33in interco TSL, k&n intake, torsion bar crank and custom made shackles
81 chevy pickup, 14bolt rear w/ locker,37in interco TSL, 8in lift,3 in body lift, straight pipe exhaust. soon to have dana 60 front,and 44in boggers!
Re: 95 rodeo front axle swap [Re: offrodeo95] #861910 01/23/08 12:45 AM
lttlbddy Offline
Lot's of people use Toyota fronts.
Re: 95 rodeo front axle swap [Re: lttlbddy] #861911 02/01/08 10:17 PM
O
does anyone know the year and model of toyota that the front axle will fit? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: 95 rodeo front axle swap [Re: offrodeo95] #861912 02/01/08 11:26 PM
strawmyers Offline
Isuzu Moderator
Toyota pickups went to IFS in '86; so the mini-truck axle '85 and older is what you're looking for. They are narrower than the Waggy axles by several inches, though. May need wheel spacers to get the width you want. Not that that's a big deal. Or for bigger bucks, you could use a Land Cruiser FJ80 axle like houlster did. They are closer to 62" wms-wms IIRC.
Sean Strawmyer
Re: 95 rodeo front axle swap [Re: strawmyers] #861913 02/02/08 07:21 AM
Triathlete Offline
The 'yotas have a different bolt pattern also.
Billy
VEHICROSS.INFO
'99 Vehicross 3"OME lift Torsion bar crank Ball joint flip 31" BFG AT's (everyday)/MTR's (wheel'n) Trooper skids OBA...more to come!
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6076 MB (Peak: 0.6727 MB) Data Comp: Off Server Time: 2026-10-24 08:16:18 UTC
