85 Front CV Axle Swap #862002 01/22/08 02:24 PM
TripleJackInGA Offline OP
Just wondering if there's a way to swap in new axles in the front without having to separate the spindle from the upper/lower control arms? Every time I do that on any car, the ball joint seals get gouged, meaning new joints, and that's just another PITA.
This is on an 85 Gen I.
TripleJack
85 GenI SWB 2.5/5-Speed on 33s
Re: 85 Front CV Axle Swap [Re: TripleJackInGA] #862003 01/22/08 04:31 PM
justice Offline
I've done it with leaving the lower connected. the top will have to be separated. You should be able to seperate them without damaging the ball joint dust boot. You have to unbolt the ball joint and strike the knuckle with a BFH (hammer) the combination of spring load of the tortion bar on the lower arm and the hammer smashing usually pops it right out.
Re: 85 Front CV Axle Swap [Re: justice] #862004 01/22/08 04:33 PM
Tag Offline
On the passenger side you can do it without poping it. Its tight but can be done.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: 85 Front CV Axle Swap [Re: Tag] #862005 01/22/08 04:36 PM
Tag Offline
If you do pop them you may as well go ahead and do the GenII UCA swap. I see you run 33's so you probably want a little more lift for playing.
Re: 85 Front CV Axle Swap [Re: Tag] #862006 01/24/08 02:44 PM
Actually, I swapped a buddy of mine with a Taco for his 31x10.50s on nice aluminum MTs recently. Yeah, they're smaller, but they look better on the truck, and no fender rub. It also has much better driveability and will actually keep up with most vehicles on the highway now.
I may look into the UCA swap anyways though.
Thanks!
TripleJack
Re: 85 Front CV Axle Swap [Re: justice] #862007 01/24/08 02:46 PM
I might just wait till I *really* have to replace them. The boot is split wide open, but I drive the truck rarely, and it's been like that since I got it a year or so ago.
TripleJack
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6136 MB (Peak: 0.6837 MB) Data Comp: Off Server Time: 2026-11-16 08:56:26 UTC
