2.6 to 2.3 diesel swap questions. #862143 01/22/08 11:08 PM
rednec_d Offline OP
ok my baby blew up on me this monday and i wasnt too happy. seeing as i cant get a title for my red diesel d-50 i was thinkin of putting the diesel into my gray truck. would it just drop in and bolt up. the diesel is an 84 Dodge D-50 4x4 5spd and the other is 84 Dodge D-50 4x4 5spd with a 2.6 motor. the red one ran and drove fine just needs a new clutch. thanks for any help.
Fueled by a 20/50 mix of stupidity and insanity
Re: 2.6 to 2.3 diesel swap questions. [Re: rednec_d] #862144 01/23/08 05:26 PM
dylanb Offline
Check out the Ranger - Montero Diesel Swap Thread just a few posts down. There are a few of us doing th same thing but with a 2.3 from a Ranger. If you've got the Dodge sitting there it shouldn't be too hard, just swap over wiring harness, throttle linkage, etc. But if all the diesel needs is a new clutch, I'd just change that.
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
Re: 2.6 to 2.3 diesel swap questions. [Re: dylanb] #862145 01/23/08 05:41 PM
rednec_d Offline OP
well see the gray ones body is better and i cant get a title for the diesel. im just trying to figure out if i can basically drop the diesel motor in without alot of mods. i was looking for a clutch last night and i found out the 2.3 and 2.6 share the same clutch. could they share the same tranny? if so i could bolt the diesel up to the 2.6 tranny and have a clutch and all. i know wiring and linkages will need work, but im just trying to find if the diesel will just bolt in.
Re: 2.6 to 2.3 diesel swap questions. [Re: rednec_d] #862146 01/24/08 06:31 PM
dylanb Offline
Same tranny and clutch setup, and you should have all the wiring and whatnot to make it work between the two trucks.
Re: 2.6 to 2.3 diesel swap questions. [Re: dylanb] #862147 01/25/08 01:31 AM
rednec_d Offline OP
so i can bolt the diesel up to the 2.6 tranny then. that is sweet man then i have two trannies. also do you think that id have to change the diffs out for the diesel or would they be ok to use the 2.6's gearing, its just a DD not a puller or offroader.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6047 MB (Peak: 0.6692 MB) Data Comp: Off Server Time: 2026-11-03 13:34:49 UTC
