Wipers #862148 01/22/08 11:48 PM
E
EyeOnCy Offline OP
Has anyone had their wipers go out? Since I got this thing the rear one has never worked. No I haven't checked power to it, I kind of assume it is getting it. Fuses by the way are fine. As far as the front goes it is intermittent until today and I hink its dead. I could get it to work from time to time by standing in the door and as I switch it on I can see the wipers lurch forward slowly by like a mm, if you catch it quick enough and 'help' it along it will work. Well today I can run it through full range of motion but it won't pick up on its own.
Anyone had this happen? Since the fronts are bad I was going to just get them both running now. Sound like a motor??
1989 Dodge Raider 2.6L/5spd
2004 Honda Element EX
1989 Dodge Daytona Shelby Z
1993 Toyota P/U
Re: Wipers [Re: EyeOnCy] #862149 01/23/08 01:27 AM
G
generation_one Offline
if they run slow and do that stuff you mentioned then it might be too little power to the motor -or needs to have the mehanisms lubricated maybe-
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Wipers [Re: generation_one] #862150 01/23/08 02:44 AM
E
EyeOnCy Offline OP
Once I get them 'unstuck' then they run fine. Is it easy to pull them apart to do that??
1993 Toyota P/U
Re: Wipers [Re: EyeOnCy] #862151 01/23/08 03:58 AM
G
dont know for sure. as easy as replacing motor
checking for voltage drop and/or putting 12 volt directly to the motor might be easier.
whatever you do,just be sure to check the diagram ....and then again
about 200k miles
Re: Wipers [Re: generation_one] #862152 01/23/08 04:13 AM
89montero Offline
I had a similar problem with the fronts and just took apart the motor and cleaned/lubed it and it worked fine.
I think new motors are north of $100 so I'd try to clean it first.
1989 Montero 4dr V6 3.0l
Re: Wipers [Re: EyeOnCy] #862153 01/23/08 05:51 AM
Kevin C Offline
Also check the wiper pivots, they get stiff with age. A couple of drops of oil on the shaft may help a lot.
Kevin
Re: Wipers [Re: EyeOnCy] #862154 01/23/08 08:04 AM
shadytree Offline
I had a similar issue on the front wipers. I tried to wipe too much mud of the windshield <img src="/forums/images/graemlins/shiner.gif" alt="" /> My issue was solved by simply tightening the bolts holding the wipers on! <img src="/forums/images/graemlins/smile.gif" alt="" />
89 Raider 3.0L V6
Re: Wipers [Re: shadytree] #862155 01/24/08 02:03 AM
E
EyeOnCy Offline OP
I'll try to go back to my hometown this weekend and take everything apart, grease, clean, etc it all to see if that helps!
1993 Toyota P/U
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6186 MB (Peak: 0.6968 MB) Data Comp: Off Server Time: 2026-07-13 18:31:05 UTC
