4.2L Intake what da? #862200 01/23/08 04:34 AM
poorboy4x4 Offline OP
Good day all,
have a easy question, I think, on my 88 the number one piston spark plug keeps going out, and the intake bolt on that same piston keeps coming loose? can I or should I use lok-tite? and? whats the torque specs? im lost
88 YJ, 4.2L, WEBER 32/36, On 33" Dunlop Mud Terrain, 4.10 ratio, tru-trac locker in dana 35...
Re: 4.2L Intake what da? [Re: poorboy4x4] #862201 01/23/08 05:38 AM
BigJim Offline
How does the spark plug "going out" What do you mean? It backs out of the hole?
As for loctight on the manifold bolt yes it is Ok. My GUESS is bout 40lbs torque on a manifold bolt.
Re: 4.2L Intake what da? [Re: BigJim] #862202 01/23/08 07:03 AM
it turns white and stops firing , I checked the compression, its good still
Re: 4.2L Intake what da? [Re: poorboy4x4] #862203 01/23/08 07:20 AM
BigJim Offline
That sounds like the mixture is too lean on that cylinder.. Could be a result of the bolt backing out and sucking air into that cylinder.. The result is the mixture is so hot it is burning the plug up.. REPAIR IT! Having an intake leak can burn both valves and pistons..
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5988 MB (Peak: 0.6540 MB) Data Comp: Off Server Time: 2026-05-29 17:35:44 UTC
