Trooper TD alternator and vacuum pump question #862207 01/23/08 07:43 AM
bobbybilly Offline OP
I am replacing my alternator and had to take off the vacuum pump from the back of it and there was oil in it. Is there supposed to be oil in it. I clean the oil up just to see the parts clearly. If there is supposed to be oil in there should I put a little clean oil in there since I wiped off all the oil that was in there. I am assuming the new alternator will not come with the vacuum pump attached. I appreciate the help.
Thanks
Billy
Re: Trooper TD alternator and vacuum pump question [Re: bobbybilly] #862208 01/23/08 04:02 PM
F
Fatso Offline
Isn't there a hose from the vacuum pump to the sump? I seem to remember on my engine that the vac pump is lubricated with engine oil. It's been awhile since I looked at it though...
1991 Isuzu Bighorn LWB 2.8TD 4JB1-TC
Re: Trooper TD alternator and vacuum pump question [Re: bobbybilly] #862209 01/23/08 05:48 PM
JLEMOND Offline
YES , THERE IS SUPPOSED TO BE OIL IN THE PUMP CAVITY, IT IS FED BY ENG OIL PRESSURE FROM THE SIDE OF THE BLOCK, JERRY
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5934 MB (Peak: 0.6464 MB) Data Comp: Off Server Time: 2026-11-03 13:39:09 UTC
