Clutch Bleeding #862433 01/23/08 11:31 PM
JoCooL Offline OP
I installed a new clutch kit in my 1991 4Runner, but now my clutch pedal is easy to push and I can't put it into gear. I'm pretty sure I need to bleed my clutch but I do not know how to do this.
Please Help and
Thank you for your time.
Re: Clutch Bleeding [Re: JoCooL] #862434 01/24/08 12:39 AM
OOP'S Offline
Same way you do brakes.
Here is a link to a FSM, it is for a 93 but it is the same.
Did you replace the clutch MC and slave cylinder? If yes you need to bench bleed the MC before install.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Clutch Bleeding [Re: JoCooL] #862435 01/24/08 02:47 AM
kewlynx Offline
Start familiarizing yourself with our Toyota section above.
LINKY
**ubi apis- ibi salus**
Re: Clutch Bleeding [Re: kewlynx] #862436 01/28/08 07:23 PM
MnMsToY Offline
It helps to gravity bleed first. That gets enough air out to build up pressure to start bleeding.
Mike
1980 Toy, Dovetail, Chevy 60/14, 5.13 gears "Wheeling isn't cheap anymore"
http://www.texas4x4.org/gallery/MikesToyota
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6009 MB (Peak: 0.6565 MB) Data Comp: Off Server Time: 2026-06-20 21:36:15 UTC
