Clutch Bleeding
#862433
01/23/08 11:31 PM
I installed a new clutch kit in my 1991 4Runner, but now my clutch pedal is easy to push and I can't put it into gear. I'm pretty sure I need to bleed my clutch but I do not know how to do this.
Please Help and Thank you for your time.
Re: Clutch Bleeding
[Re: JoCooL]
#862434
01/24/08 12:39 AM
Same way you do brakes. Here is a link to a FSM, it is for a 93 but it is the same. Did you replace the clutch MC and slave cylinder? If yes you need to bench bleed the MC before install. http://personal.utulsa.edu/~nathan-buchanan/93fsm/
"Serenity through Sobriety"
Re: Clutch Bleeding
[Re: JoCooL]
#862435
01/24/08 02:47 AM
Start familiarizing yourself with our Toyota section above. LINKY
Re: Clutch Bleeding
[Re: kewlynx]
#862436
01/28/08 07:23 PM
It helps to gravity bleed first. That gets enough air out to build up pressure to start bleeding. Mike
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6002 MB (Peak: 0.6558 MB) Data Comp: Off Server Time: 2026-07-09 17:11:11 UTCValid HTML 5 and Valid CSS
