Re: Dome light, or dumb light
[Re: OldColt]
#863600
01/25/08 03:34 AM
Mine quit working to to the rivets and the plastic, so I replaced it with a round dome light from a camper. Works good now.
1988 2DR 5SP 2.6l Monty. Balance shaft elimination kit installed. 120k miles. Timing jumped, pulling motor to see what needs to be done.
[Re: billygoat]
#863601
01/25/08 06:20 AM
I put some conductive epoxy on the rivets on mine... Door switches still are a bit hit or miss.
Kevin
[Re: OldColt]
#863602
01/25/08 02:19 PM
Mine almost never works, even if I fiddle with the dome or door switchs. Every now and then, when Venus is in retro-grade and someone in the world somewhere has just butchered a chicken, I'll open my door and it'll work. No rhyme or reason and if I touch any of the switches, or close and reopen the door, it goes out. <img src="/forums/images/graemlins/zombie.gif" alt="" /> I've tightened the rivets on the light, cleaned the contacts, checked for voltage and replaced the bulb. Now I keep a hand crank led flashlight in the truck for when I need to see at night. <img src="/forums/images/graemlins/notooth.gif" alt="" />
-Todd 1987 Montero 2.6l 5-speed (Sold...but I still miss her) 2008 Jeep Patriot Sport 4x4
[Re: toddstidham1]
#863603
01/26/08 07:16 PM
Mine didn't work when I got it. I took the light itself off the ceiling and cleaned it before I noticed the PO had actually removed the switches off the doorframes. <img src="/forums/images/graemlins/confused.gif" alt="" /> I ended up getting new ones from a Mitsu dealer. The driver's door switch is a "2-wire" and the other 3 are single wire switches. You can modify a 2-wire to make a single wire one.
[Re: daan]
#863604
01/28/08 06:02 PM
Never had any trouble with the dome light, but the map lights suck. They usually work after wiggling the switches and turning them on/off 5 times. I'm sure I just need to clean the switch, but I don't use them enough to care.
[color:"red"]1992 Monty SR, bouncy seat, custom steering wheel, torsion lift, BFG 31" AT, luxurious wood interior. 230k. [/color] "Give the bully another point."
