88 v6 4runner timing #863716 01/25/08 12:32 AM
toyotateen88 Offline OP
im having a problem keeping my 4runner in time i jus had new tensioners and timing belt and water pump replaced i have used the timing light and put in in time three times now and it keeps slipping out any help would be nice its my only car at the time thanks.
shane,88 toyota 4runner, v6, 5spd, 31x10.5x15 pro comp mudders, pacer wheels, flowmaster exaust, cold air intake.
Re: 88 v6 4runner timing [Re: toyotateen88] #863717 01/25/08 01:07 AM
Adam F Offline
Any DTC's/codes?
97 4R, stock, daily driver
Re: 88 v6 4runner timing [Re: Adam F] #863718 01/25/08 02:43 PM
no its not pulling any trouble codes
Re: 88 v6 4runner timing [Re: toyotateen88] #863719 01/25/08 07:17 PM
4Crawler Offline
Are you using the timing check jumper?
- http://www.4crawler.com/4x4/CheapTricks/index.shtml#TimingCheckConnector
And does the base timing change when you install the jumper?
If not, check the Throttle Position Sensor IDL-E2 connection:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
And if all that is OK, make sure the distr. hold down is secure. I once had a problem in my old FJ55 Landcruiser where the hold down clamp was slightly deformed and while it seemed tight, the distr. could move around under load and engine vibration.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6012 MB (Peak: 0.6563 MB) Data Comp: Off Server Time: 2026-05-29 23:51:16 UTC
